2002 VTXC 1800 Fuel Lights and Tank Capacity - VTXOA
 12Likes
post #1 of 11 (permalink) Old 05-12-2019, 07:36 AM Thread Starter
Hi Everyone,
New to this group and just bought a 2002 1800C with pretty good nick. I understand the fuel capacity is about 5.5 US gallon and 4.5 something UK gallon. Fuel light comes on after 80 miles and when I fill up it only takes about 11.5 litre which is roughly about 2.5 UK gallons.
Even then it averages about 32-35 miles per gallon and its all mixture of town and motorways etc. I'm around London UK. Any tech gents out there if there is an issue with the fuel warning lights etc.?
Cheers
S
Noisy Rodent is offline
post #2 of 11 (permalink) Old 05-12-2019, 10:51 AM
Correction......Fuel Capacity is a "Claimed" 4.49 US gallons with actual around 4 gallons
Your 32-35 MPGs is right in the normal range the VTX is thirsty and it has a small fuel tank
post #3 of 11 (permalink) Old 05-12-2019, 11:39 AM
^^^^What Spike said. 4.49 gal. US. I average 35-58 mpg, and my blue low fuel light can come on anywhere from 3.5 to 3.8 gal., which tells me find a gas (petrol) station in the next 25 mi. or prepare to push/ walk.
chuck_VTX F likes this.
post #4 of 11 (permalink) Old 05-12-2019, 11:46 AM
Trade it in for a 2nd Generation 1800C, 2005 or later..
More smiles!
chuck_VTX F and rangers4u like this.
post #5 of 11 (permalink) Old 05-14-2019, 12:24 AM
If that is miles per imperial gallon, the mileage is poor even allowing for the limited open roads in the UK.
I consistently get 39-43 miles per US gallon on my 2002 1800C even riding two up. MPG for imperial gallons should be 20% higher in theory.
As stated, the early 1800C with the internal fuel pump only holds about 4.5 US gallons. If you fill it with the bike upright, not on the side stand, you will get close to that amount.
X-Brit is offline
post #6 of 11 (permalink) Old 05-14-2019, 12:30 AM
Wavey Dave's Avatar
Location: I live in the UK in South Yorkshire in a town called Rotherham
I average 32-35MPG (UK) on a long run that can go up to 45mpg I think she is a thirsty girl because I like to feel the torque using W.O.T in the right gear. I am sure if I rode her more moderately around town and rural twisties she would do much better. but W.T.F why have all that oomph on tap and not play :+)
rangers4u and Bikerbob1 like this.
Wavey Dave is offline
post #7 of 11 (permalink) Old 05-14-2019, 03:14 AM
Bikerbob1's Avatar
Originally Posted by Noisy Rodent View Post
Hi Everyone,
Cheers
S
When I first got my 1800N, I took it for a ride, and the fuel light came on at about half-way through the tank. (about 2.2 U.S. gal.). does fine now, coming on with about a gallon left. I'm thinking it's a little float that may tend to stick if the bike isn't driven regularly. I'd suggest taking it over some cobblestones, or another bumpy road to free the float.
Hope it helps!
Smoke 'em if you got 'em!
Bikerbob1 is offline
post #8 of 11 (permalink) Old 05-14-2019, 08:26 AM
Hope it helps!
The sensor is a thermistor aka resistor that changes resistance depending on temperture.
When in fuel it is a high resistance, when in air the current flow warms it up and resistance goes down
and the low fuel light goes on.
Early 1800 have it on the in-tank fuel pump bracket.
Late models with external FP have the thermistor on a small arm.
File Type: png 1800 low fuel sensor 2nd gen with ext fuel pump.png (74.6 KB, 4 views)
post #9 of 11 (permalink) Old 05-14-2019, 09:44 AM
BobSill's Avatar
Hi Everyone,
Cheers
S
I usually can average 43 mpg at 80 miles per hour on HWY driving on my 2002 1800R with Honda windscreen and saddle bags.
Also stand the bike up right when fuelling it up it does make a difference with the fuel light coming on at around 150 miles verses 120 miles on the side stand! ( the C just has that smaller tank capacity)
BobSill is online now
post #10 of 11 (permalink) Old 05-14-2019, 09:59 AM
It has a LOT to do with these factors;
Has the Fuel Pressure Regulator, or FPR, been changed yet? See this for more;
https://tech.bareasschoppers.com/car...ure-regulator/
What pipes
What airbox
Is there a fuel manager in play?
How well is it tuned and for what? Max power or Max mileage
What fuel octane rating is he using? You should be using the LOWEST octane available as Honda engineers designed it to run best on low octane fuel not premium
Tire pressures? 38-40psi for both
The roads he rides on most often and at what speeds
Any one of these can fluctuate the MPGs by one or two miles and if several are in play then 32-35 mpgs is certainly possible
BobSill likes this.
