Starter? 2005 VTX1800R - VTXOA
  • 1 Post By chuck_VTX F
post #1 of 10 (permalink) Old 06-11-2019, 06:11 PM Thread Starter
Angry Starter? 2005 VTX1800R
When I hit the start button it will do one of the following.
Start immediately with no problem.
or
Turn the engine over very slow to the point of my trip odometer resetting. (Battery can't supply enough voltage and lights go out)
When this happens, I wait a couple of seconds and again it will either start immediately or turn over extremely slow.
New Battery
New Ford Solenoid to handle high current.
Bike runs great.
45,000 miles.
The best chance of starting when the bike is in neutral.
Any ideas?
greymoment is offline
post #2 of 10 (permalink) Old 06-11-2019, 06:33 PM
Clean and lube your starter button.
post #3 of 10 (permalink) Old 06-11-2019, 06:34 PM
Click this from the How To board https://www.vtxoa.com/forums/73-how-...itch-mtce.html
post #4 of 10 (permalink) Old 06-11-2019, 07:51 PM
this is WHAT,, 5 this week....
15 years.. and still no one knows... to clean the switch.
chuck_VTX F is online now
post #5 of 10 (permalink) Old 06-11-2019, 08:32 PM
enduro's Avatar
Start switch is working because the starter relay is energizing and the starter current does not go thru the switch. Intermittently there is not enough voltage/current to the starter motor, the voltage drops trying to supply enough current and the odometer resets from the low voltage. You have a bad/weak/loose connection at the battery terminals + or -, or your ground to the frame/motor is poor. BE SURE your battery terminals are tight! I know there is a ground fix for the 1800 but I'm not familiar with that. Where your ground cable connects could be an issue.
enduro is offline
post #6 of 10 (permalink) Old 06-11-2019, 09:06 PM
that is not totally correct....
limited current to solenoid... can lightly hold contacts closed... causing them to burn even more...
but other wise you are correct...
post #7 of 10 (permalink) Old 06-13-2019, 01:01 PM Thread Starter
Maybe Bad Starter?
I traced the electrics from the switch with the wire disconnected from the solenoid. Steady 12V on numerous tries with the start button. I decided to remove the starter. There is sideways and vertical play in the spline bearing. Not sure if this is normal. The vertical play is much greater than the sideways play. Could the armature be to close to the starter frame at times because of the sideways movement? The starter is a "Mitsuba SM-13".
BTW, taking the starter out was no piece of cake.
post #8 of 10 (permalink) Old 06-13-2019, 01:10 PM Thread Starter
I traced the electrics and all is fine. Disconnected wire on the solenoid and repeatedly tested button. Constantly over 12V. Removed the starter and have sideways play on the spline of the starter. Also, there is a vertical play. You can shake the starter and the armature moves back and forth. Not sure, but this does not seem normal.
BTW, removing the starter was not a piece of cake. tehe
post #9 of 10 (permalink) Old 06-14-2019, 10:03 AM
Rare to see a starter motor fail.
https://www.partzilla.com/catalog/ho...starting-motor
Service Manual section 18 shows the needle bearings on the front cover.
There should not be much play. Take it apart and inspect.
post #10 of 10 (permalink) Old 06-14-2019, 01:28 PM
Mrjo1340's Avatar
I had the exact same issue on my 2006 1800 c. I ended up replacing the starter assembly switch because when I cleaned it it would work for about a week or two and then the same thing would happen over. I'm not sure why these bikes are notorious for starter assembly switch issues. I've owned more bikes that I care to remember and this is the only one that has this issue as there are so many threads with the same narrative.
Mrjo1340 is offline
Tags
starter , starter bogs
