cranking - VTXOA
post #1 of 11 (permalink) Old 06-13-2019, 09:41 AM Thread Starter
robbiebobbie's Avatar
cranking
I hv an 08 1800....on a cold start daily it usta bust over on 2nd or 3rd turn of the starter but lately it take several and sometimes I don’t think it’s going to start....I can hear the fuel pump when the key is turned on any ideas.....tia
robbiebobbie is offline
post #2 of 11 (permalink) Old 06-13-2019, 10:41 AM
When it does start, how does it run? If it has trouble idling when it's cold, I'd look at the wax valve.
https://www.vtxoa.com/forums/97-1800...links-pdf.html
post #3 of 11 (permalink) Old 06-13-2019, 11:02 AM
2nd or 3rd try????!!!!! Mine always started on the first try, except when the battery was dying. A EFI bike should start on the first try every time.
post #4 of 11 (permalink) Old 06-13-2019, 11:42 AM
I read it as 2nd or 3rd revolution of the engine not 2nd or 3rd try.
Chicago-Spike and rangers4u like this.
post #5 of 11 (permalink) Old 06-13-2019, 11:44 AM
Ahhh, my bad if this is the case.
Harkon likes this.
post #6 of 11 (permalink) Old 06-13-2019, 12:03 PM
Or by the 2nd or 3rd the engine will barely crank because the battery is dying...
Weak batteries create more problems..
Harkon and rangers4u like this.
post #7 of 11 (permalink) Old 06-14-2019, 02:33 AM Thread Starter
yes the 2nd or 3rd turn of the starter but recently it takes several seconds to start or in other words the starter turns over many times.....the battery is ‘t dragging down
post #8 of 11 (permalink) Old 06-14-2019, 09:33 AM
Cold start issue - go with the what Harkon said on a previous post with a link.
Since the 1800 needs a good ground for the FI, I would suggest the Ground Fix at the Common Electronics Ground at the front Ign coil.
There is another Ground cable from the starter motor to the frame under the radiator.
One VTX owner cleaned the ends and that cleared his issues.
Remove and reseat the Camshaft position sensor.
Sojourner Senior Member 26May2016 said::
I had a similar problem and it ended up being the connection to the cam pulse generator.
The connection was corroded. You can find the connection on the front jug, left side, near the
cam cover facing the radiator.
Any mods done to airbox?
Any FI codes flashing?
post #9 of 11 (permalink) Old 06-16-2019, 07:20 PM Thread Starter
[QUOTE=Hans&Feet;4595590]Or by the 2nd or 3rd the engine will barely crank because the battery is dying...
Weak batteries create more problems..[/QUOTE
post #10 of 11 (permalink) Old 06-16-2019, 07:22 PM Thread Starter
no mods or codes and when it starts up it runs great
