New bearings - VTXOA
post #1 of 20 (permalink) Old 06-25-2019, 01:00 PM Thread Starter
New bearings
Hi there, after going back and forth with trying to determine what the issue with my wobble was.i have decided to t a new set of bearings.
I ride a VTX 1800 R 2004. Wanted to ask what is best to do based on your experience. Purchase OEM or purchase all balls bearings?
Any other things I need to consider buying besides the washer?
Thank you In advance.
Irod2 is offline
post #2 of 20 (permalink) Old 06-25-2019, 01:22 PM
1300 had bicycle stem bearings, I upgraded to tapered All Balls bearings like 1800 used.
I re-used the lock washer.
I changed the stem bearings because of weird feedback in turns.
When tire replaced, weird feedback was gone.
A few tires later I installed a Metz front tire, at some de-cel times for a light or a stop I would let go of the grips.
A wild handlebar movement occurred, a tank slapper that I arrested.
21k miles later I got ride of that tire and no tire since has had a wobble.
Check the stem for the 12 ft-lbs torque.
Tighten to 30 ft-lbs, push HB lock to lock, loosen, retorque to 12 ft-lbs.
Front Tire is more likely the problem than the bearings.IMO
post #3 of 20 (permalink) Old 06-25-2019, 04:05 PM
How old are your tires? What pressures do you run? They could be cupped
post #4 of 20 (permalink) Old 06-25-2019, 06:23 PM Thread Starter
Thank you for the responses. They are a bit cupped. However I know my bearing races are in bad shape. Bearings were dry when I took them out to inspect. Races got some damage. If I torque them a bit bast what I should I can feel them sitting while steering column is straight. So I figured I would change them.
Not sure if I should do the all balls or OEM though.
Irod2 is offline
post #5 of 20 (permalink) Old 06-29-2019, 02:52 AM
ervin260's Avatar
Why All Balls? There are quality bearings from reputable manufacturers available on the market, I guess...
Xman/qc likes this.
VTX 1800/280
You can say anything stupid. It's the internet. No real consequences for YOU.
ervin260 is offline
post #6 of 20 (permalink) Old 07-05-2019, 07:43 PM Thread Starter
Seems to be the brand of choice when going through the different forums.
Do you have any other options?
Irod2 is offline
post #7 of 20 (permalink) Old 07-05-2019, 07:44 PM Thread Starter
Hans, any feedback in regards to how to pack the new lower bearings in? I can probably cut the old ones out with a dremmel.
Irod2 is offline
post #8 of 20 (permalink) Old 07-05-2019, 10:16 PM
A Dremel cut and bit of heat should work.
I used a sharp chisel to get the lower race off. Seems I may have used a Dremel also
I also sanded the stem for a light press fit.
A strip of sand paper and twist the stem
around a dozen times x 5.
Wheel bearing grease, automotive or
boat trailer wheel bearing grease.
Use the stem bearing procedure from the SM.
post #9 of 20 (permalink) Old 07-05-2019, 11:19 PM
Hans,
You may want to mention what grit sand paper you used just to clarify.
2002 1800C ILLUSION BLUE Bought new 1st one sold in WI. - Cobra angle slash cuts - Cobra FI2000 - Memphis Fats 21" - Hondaline 24L bags with Easy Brackets - Corbin Gunfighter and a lot more.....
Jim Travis is offline
post #10 of 20 (permalink) Old 07-06-2019, 01:06 AM Thread Starter
Thanks buddy.
Irod2 is offline
