Does anyone know where I can find a complete diagram of the cooling system? - VTXOA
 36Likes
post #1 of 50 (permalink) Old 07-10-2019, 02:27 PM Thread Starter
Mrjo1340's Avatar
I have a small coolant leak that I can't seem to isolate. I have tightened the clamp around the coolant reservoir and still it has a very small gradual leak.
I looked underneath and everything is dry and no evidence of any leaked. Any help would be appreciated
Mrjo1340 is offline
post #2 of 50 (permalink) Old 07-10-2019, 03:12 PM Thread Starter
Mrjo1340's Avatar
A water pump has crossed my mind as well but I want to make sure all other possibilities have been eliminated before I go that route.
Mrjo1340 is offline
post #3 of 50 (permalink) Old 07-10-2019, 04:43 PM
under the water pump is a small hole... if fluid is dripping from the hole.. its the water pump.
just like most cars.
Honda service manual page 6-0.. complete diaphragm of cooling system
2005 VTX1800 F, type II, Silver Tribal, 88,000 Miles, Purchased Feb, 2005.
post #4 of 50 (permalink) Old 07-10-2019, 06:05 PM Thread Starter
Mrjo1340's Avatar
Let's talk worst case scenario for a moment. If it's the weep hole in the water pump, can that be fixed or do I have to bite the bullet and replace it?
Also, how much does a new water pump go for ? Does it have to be OEM? I'm just throwing some scenarios out there. I hope it's something simple but I always hope for the best but expect the worst
Mrjo1340 is offline
post #5 of 50 (permalink) Old 07-10-2019, 06:25 PM
No fixing, no rebuild kits, just buy a new pump and change it out
nate6966 and ladrox63 like this.
post #6 of 50 (permalink) Old 07-10-2019, 08:56 PM
DrDolittle's Avatar
Pressure test?
DrDolittle is offline
post #7 of 50 (permalink) Old 07-10-2019, 10:49 PM Thread Starter
Mrjo1340's Avatar
As much as I like to figure things out on my own, this one unfortunately is out of my scope. I'm going to take it to the shop I deal with.I hope it's just on whoring or maybe a loose hose and not the water pump.
Mrjo1340 is offline
post #8 of 50 (permalink) Old 07-11-2019, 08:56 AM Thread Starter
Mrjo1340's Avatar
Quick last question. How is it determined if the water pump is faulty or not? Is there a specific test that will yield a definitive answer?
Mrjo1340 is offline
post #9 of 50 (permalink) Old 07-11-2019, 09:20 AM
The definitive answer is the leak you have on the ground. It's from the water pump, thus the water pump is going bad. The fix is to replace the water pump
PS...it's not a hose, or a loose clamp, it's the pump
TennX, ervin260, gsvtx and 2 others like this.
post #10 of 50 (permalink) Old 07-11-2019, 09:23 AM
Look up by the rear oil drain plug as you can see in this picture. The weep hole is the dirty hole near the drain plug;
gsvtx and DrDolittle like this.
