Desmog - Page 2 - VTXOA
post #11 of 19 (permalink) Old 07-29-2019, 05:35 PM
TedlyM59's Avatar
Hey I don't mean to be so ignorant. My 2008 1800 VTX has a PCIII. Do I need a desmog kit? and Why? I get 38 MPG no popping on de-cel.
Ted
08 VTX1800F Cobra pipes, PC III, ROX 2"risers
"I have never been lost. I was once bewildered for three days, but I was never lost." Daniel Boone
TedlyM59 is offline
post #12 of 19 (permalink) Old 07-29-2019, 06:58 PM
pushrod's Avatar
Ted
I plan to do mine sometime in the coming couple of weeks. I am only doing mine because removing my PCIII has caused a few issues like crappy sound exhaust, and exhaust popping when I decelerate. I do like the extra MPG's im getting but would prefer for it to sound better and run smoother.
2003 VTX 1800R
pushrod is offline
post #13 of 19 (permalink) Old 07-30-2019, 08:49 AM
Ted
You do not NEED to desmog. Some have said they have little to no popping after removing all the junk, but that didn't happen for me. Changing exhaust gaskets did that for me. Getting rid of all that junk makes for a cleaner looking engine, makes it easier to access the valves for adjustments, and if you dress up your ride with some lights or such it makes the shiny stuff visible. Besides shedding a few pounds too.
post #14 of 19 (permalink) Old 07-30-2019, 09:17 AM
Ted
Here, read this;
https://tech.bareasschoppers.com/eng...x-1800-desmog/
post #15 of 19 (permalink) Old 07-30-2019, 01:07 PM
pushrod's Avatar
If I was not having some issues that this may correct I wouldn't be doing the mod. I don't like fixing things that are not broken.
2003 VTX 1800R
pushrod is offline
post #16 of 19 (permalink) Old 07-31-2019, 10:42 AM
TedlyM59's Avatar
Well thanks Mike and Spike for the link for the Desmog and secondary air system removal. Well I guess I have some work to do. Oh yes order the parts first.
TedlyM59 is offline
post #17 of 19 (permalink) Old 08-01-2019, 09:58 AM
pushrod's Avatar
I got my desmog kit yesterday. When my grandson leaves for the summer I'll have some time to put it in.
2003 VTX 1800R
pushrod is offline
post #18 of 19 (permalink) Old 08-02-2019, 09:36 AM
Ummm, this won't correct any issues at all with the running of the engine??? As the PAIR system is after the combustion chambers, it will not effect how the engine is running. All this really will do is clean up the top of the cylinders to make more room for valve inspections and it might decrease the amount of deceleration popping.
So what issues are you having that need addressing?
post #19 of 19 (permalink) Old 08-02-2019, 10:20 AM
pushrod's Avatar
1. popping on decel after the engine has warmed up, it doesn't do it cold
2. At low speed, trying to hold the throttle at the place where its a steady speed, neither accelerating or decelerating but holding a steady speed anywhere between 25 to 45 mph, the engine coughs, sputters, lurches, surges and the exhaust will be popping. Any slight increase or decrease in throttle at all and the engine smooths out, so I have to continually speed up slightly, then slow down, the speed up slightly again. As long as I am accelerating or decelerating even slightly it is smooth. Once I am up to 50 mph or faster it's smooth.
My PCiii started giving me problems a while back so I went back to the OEM setup and that's when it all started.
2003 VTX 1800R
pushrod is offline
