New Battery with Backwards Polarity - Page 2 - VTXOA
 5Likes
post #11 of 17 (permalink) Old 09-01-2019, 02:42 PM
AZrider43's Avatar
Happened to me as well, also batteries plus. I just touched the last terminal on and it sparked, it blew one fuse under the left side cover. Check them all to be sure.
Red 2004 1800N
AZrider43 is offline
post #12 of 17 (permalink) Old 09-01-2019, 03:40 PM
Hope all is well OP...for me nuttin but yuasa....good luck
TennX is offline
post #13 of 17 (permalink) Old 09-02-2019, 08:15 PM
If it were a fuse, it would not start at all. As I read it, the engine will start and dies a short time after. That's not a fuse problem
post #14 of 17 (permalink) Old 09-02-2019, 11:19 PM
Many mysteries in life.
Reverse voltage the starter motor should run backwards, sprag should not engage, engine should not crank over.
Correct voltage - possibly starter relay stuck and cranked engine for an extended time.
Many mysteries.... did it run?
Chicago-Spike likes this.
post #15 of 17 (permalink) Old 09-03-2019, 03:26 AM
Even I am having the same problem and what is ECU exactly? Can anyone help?
Masticate is offline
post #16 of 17 (permalink) Old 09-03-2019, 09:11 AM
As I said above, it is the Engine Control Unit or the brains of the engine and it is the black box right on top of the battery with the wire harness plugging into it.
post #17 of 17 (permalink) Old 09-07-2019, 04:45 PM
Exclamation New Battery with Backwards Polarity
just check the terminals on the back coil ....
RUMBLEVTX1800C is offline
Tags
battery polarity
