2007 VTX1800F Fuel issue - VTXOA
  • 1 Post By Hans&Feet
post #1 of 7 (permalink) Old 09-07-2019, 05:11 PM Thread Starter
Hello - I have 2007 1800F with 2000 miles that I have owned since new. I have everything except fuel (or so I think) to start engine. Bike will fire if I inject fuel into the throttle body. No error codes, newer battery & voltage is good, fuel pump sounds like it is pressuring up and then stops after 3-4 seconds. FI lights up as usual (no blinks) and then turns off. Spark plugs just cleaned. All of the threads I can find are for pre-2005 that show a fuel pressure regulator. I have disconnected main fuel line and lifted tank but it appears that there is only a fuel rail and no FPR. Should I check the fuel flow by disconnecting the fuel line going into the rail? Also, if I do, will there still be enough fuel in the system for the test? Thank you.
File Type: jpg 7641268A-1B11-4360-85D4-F76DAD1B46E5.jpg (349.9 KB, 4 views)
jasparrow is offline
post #2 of 7 (permalink) Old 09-07-2019, 10:45 PM
2,000 miles... when was it last ridden?
Injectors could be clogged up. There is a fine mesh screen on the injector.
Fuel filters in canister could be clogged.
3-4 seconds of FP running is the prime..If it is cranking or running than FP continues to run..
Take off fuel line and see what comes out..
ervin260 likes this.
post #3 of 7 (permalink) Old Yesterday, 03:33 AM
ervin260's Avatar
First check pressure at the rail!
VTX 1800/280
ervin260 is offline
post #4 of 7 (permalink) Old Yesterday, 04:46 PM Thread Starter
Last ridden about 4 mos. ago for only about 1 mile. Canít seem to find repair manual pdf for 2005-2008 except for Clymer or original Honda (used) for $134 so I am kind of in the blind. Where is the canister with the fuel filters located? I will update you after I remove the incoming line to the fuel rail and check the fuel pump pressure if I can find a fitting that works. Thank you both for the feedback.
post #5 of 7 (permalink) Old Yesterday, 09:41 PM
Ex-Rocket's Avatar
If only 2000 miles on a 2007 bike then this bike is being mistreated. How old is the gas that is in the tank? If old , drain the old gas out and replace with fresh and change the fuel filter
Ex-Rocket is online now
post #6 of 7 (permalink) Old Yesterday, 11:05 PM
http://www.californiavtxriders.com/p...582ec23ee1500e
External FP
Somewhere was a link that had a badly polluted canister.
post #7 of 7 (permalink) Old Today, 11:00 AM Thread Starter
Thanks for the replies and link. I will try to check pressure at the rail or pump outlet and go from there.
