2002 1800c Different valve clearances - Page 3 - VTXOA
post #21 of 25 (permalink) Old 09-19-2019, 10:40 AM Thread Starter
Well we will find out tomorrow. just cut 1/8th inch rubber and cork fuel rated gaskets and sealed them on the head side of the gasket. Takes 24 hours for the gas rated liquid gasket to setup and then I will have everything together. If this leaks I would be very surprised
tc862011 is offline
post #22 of 25 (permalink) Old 09-19-2019, 12:33 PM
Bri720a's Avatar
Just a thought, or maybe I misunderstood where you are talking about the leak, but I have had leaks on rubber hoses/tubes previously from over tightening clamps. (yes it sounds counter intuitive but absolutely happens)
If I remember correctly the metal clamps on the intake boots are not the best and it may be possible to just make them snug and not super tight, they may seal better that way.
Good Luck. Looking forward to hearing about the solution.
Brian
2003 VTX 1800R - Cobra Speedster Longs - K&N w/decapped stock air box - Power Commander III, Rostra Cruise =
Bri720a is offline
post #23 of 25 (permalink) Old 09-19-2019, 12:38 PM Thread Starter
I did buy new clamps and snugged them pretty good. The bike doesnít react when I spray the clamp side just the flange side. Iím hoping this is the fix. Love the bike and rides awesome anywhere other then low speed light throttle and Iím sure it will run even better all the way through when there isnít an intake leak lol
tc862011 is offline
post #24 of 25 (permalink) Old 09-20-2019, 01:06 PM Thread Starter
Making the gaskets was the fix. Got everything on and let everything dry and when I started it I soaked the intake boots with carb clean and there was zero reaction. Letís hope itís a permanent fix
tc862011 is offline
post #25 of 25 (permalink) Old 09-20-2019, 02:28 PM
fastspek's Avatar
Glad you could fix it.
According to the manual the insulator band distance should be 9 mm(0.4 inch). Less or more could be the cause of leaking.
brothers in arms:
2003 VTX 1800C (new)
2002 HD FLSTF since 07/2008
fastspek is offline
