rear brake pedal play - how much? - VTXOA
  • 1 Post By fastspek
  • 1 Post By Badmunky
post #1 of 6 (permalink) Old 09-29-2019, 07:24 PM Thread Starter
I looked in the manual, but I could not find the answer. Searches also turned up zip.
how much play should I have in the rear pedal? Is there a way to adjust it?
I just finished changing the brake lines and I am not sure if there is air in the lines or I am paranoid.
Do not go gentle into that good night. Rage, rage against the dying of the light - Dylan Thomas
All that is necessary for the triumph of evil is that good men do nothing - Edmund Burke
If you can, help others; if you cannot do that, at least do not harm them. - Dalai Lama
Mowoc is offline
post #2 of 6 (permalink) Old 10-01-2019, 04:31 PM
fastspek's Avatar
You can adjust the pedal hight but not the play since it is a hydrolic brake system.
Curt E likes this.
brothers in arms:
2003 VTX 1800C (new)
2002 HD FLSTF since 07/2008
fastspek is offline
post #3 of 6 (permalink) Old 10-09-2019, 10:30 AM
Badmunky's Avatar
They will have a little play in them. But not a lot.
Curt E likes this.
"Speed has never killed anyone, suddenly becoming stationary… that's what gets you." Jeremy Clarkson.
Badmunky is offline
post #4 of 6 (permalink) Old 10-09-2019, 10:36 AM
I raised mine slightly, after adding small floorboards on my C. Shifter as well.
post #5 of 6 (permalink) Old 10-10-2019, 11:10 AM Thread Starter
I think I am being paranoid.
the pedal holds firm and there is no spongy feeling when I use it. I bled it a couple of times and no bubbles came out. I used a vacuum pump over a speed bleeder so I think that is OK too.
Is there any other sign of air in the lines other than spongy pedal or no hard stop when the pedal locks up?
Mowoc is offline
post #6 of 6 (permalink) Old 10-10-2019, 11:13 AM
Bri720a's Avatar
Sounds like you have got it to me!
2003 VTX 1800R - Cobra Speedster Longs - K&N w/decapped stock air box - Power Commander III, Rostra Cruise =
Bri720a is offline
