OEM length brake/clutch lines with 10" ape bars - VTXOA
post #1 of 3 (permalink) Old 10-22-2019, 04:14 PM Thread Starter
Johnzz1420's Avatar
Hello JohnZ here. Been awhile since I last posted. Question: I'm contemplating putting 10" ape bars on my VTX1800N. Will the stock length brake & clutch lines fit on 10" ape bars or do they have to be replaced with longer lines? If this is the case, will the stock brake\clutch lines fit on 8" mini ape bars instead? Secondly, what size risers should I be lookin at? Thanks fer yer input!!!!
Johnzz1420 is offline
post #2 of 3 (permalink) Old 10-23-2019, 12:15 PM
I don’t think you can use the stock brake lines and taller bars.
I put c risers on my r and it stretched stuff to the max. The whole kit is sealed - I think you will need a custom line kit.
Do not go gentle into that good night. Rage, rage against the dying of the light - Dylan Thomas
All that is necessary for the triumph of evil is that good men do nothing - Edmund Burke
If you can, help others; if you cannot do that, at least do not harm them. - Dalai Lama
Mowoc is offline
post #3 of 3 (permalink) Old 11-08-2019, 09:20 PM
NickD's Avatar
They'll work as long as you don't go over a 2" riser
NickD is offline
