02 1800 wont start - Page 2 - VTXOA
 4Likes
post #11 of 19 (permalink) Old 11-17-2019, 10:49 AM Thread Starter
Depotman's Avatar
My FI came on and had about 3 sec steady light and 3 flashes.
The Bareass doesn't list this sequence.
Buke wont start or getting to the injectors or theottle body.
Depotman is offline
post #12 of 19 (permalink) Old 11-17-2019, 10:59 AM Thread Starter
Depotman's Avatar
Had it on a tender.
Just doesnt get fuel to injectors.
Pump primes, got fuel to rail
Nothing hitting Fuel injectors or throttle body.
Anything else you suggest to check?
Fuel pressure?
Fuses are all good.
Have a Commander 3 on it ( wonder if it went south?
New battery.
( Honda dealer is 300 miles away)
Depotman is offline
post #13 of 19 (permalink) Old 11-17-2019, 11:22 AM
Disconnect the PC3 from the ECM and injectors.
It controls the injectors.
Several have failed.
Is the PC3 getting +12v volts and is the Ground wire connected?
On another note, check the 2 pin connector with Red, and Red/White wires.
It is near the Starter Relay.
The Red, and Red/White wires are the wires from the two 30 amps fuses to the Main cable harness.
One 30 amp for the FI system and one 30 amp for everything else.
The FI connection has burned open several times. over the years.
https://tech.bareasschoppers.com/tec...d-main-wiring/
I suspect the PC3 has expired.
post #14 of 19 (permalink) Old 11-17-2019, 12:58 PM Thread Starter
Depotman's Avatar
Do you know of a link to show hw to unwire the PC 3?
What do you connect when the PC3 is disconnected.
PC3 has the 2 lights on when the key is on but with Kill switched engaged they stay steady and do not flash when kill switch is on and turning over the bike.
By the way
Thank you
Depotman is offline
post #15 of 19 (permalink) Old 11-17-2019, 01:51 PM
Where there is a wire or cable that goes to the ECM or injectors remove it and re-install the OEM connectors. I believe there are two versions of PC3, PC3 and PC3-USB. One has a 22 pin connector to the ECM, the other connects at the injector connectors.
Depotman likes this.
post #16 of 19 (permalink) Old 11-17-2019, 09:05 PM
13 Engine doesn’t start
Loose or poor contact on front injector connector
Open or short circuit in front injector connector wire
Faulty front injector
pushrod likes this.
post #17 of 19 (permalink) Old 11-18-2019, 12:00 AM
Is that the FI light when booting up with fuel pump prime???
Error codes are 1.3 seconds for the long pulse for the 10's count. .5 seconds for the ones count..
I do not have a 1800 so I do not exactly know all the sequence of events!
post #18 of 19 (permalink) Old 11-18-2019, 02:30 PM Thread Starter
Depotman's Avatar
Got it running
Removed the PCommander 3
POS!
Lol
Thanks guys
Hans&Feet likes this.
Depotman is offline
post #19 of 19 (permalink) Old 11-18-2019, 07:41 PM
Got it running
Glad to see you're on the road again. If you're running after-market exhaust and are bothered by decel popping you might consider the Cobra Powrpro to take the place of the PC3. I replaced my PC3 a number of years ago when Cobra first came out with the Powrpro and (touch wood) it's been running flawlessly. Truly plug 'n play and it works constantly trimming the A/F for top performance. Decel popping gone too.
Sojourner is offline
