Will not start please help - VTXOA
post #1 of 7 (permalink) Old 07-19-2012, 01:02 PM Thread Starter
04 1300s Battery tendered for along time - years
Ride evey day-except last 8 weeks (hip replacement)
Bike started just fine,rode to home depot, started up again then off to last Dr's visit about 15miles total.
After therapy bike would not start or even crank - no sound at all.
Had lights and horn, 1st gear kickstand up, neutral ignition on kill switch off.
2004 VTX1300S Silver
mlips is offline
post #2 of 7 (permalink) Old 07-19-2012, 01:11 PM
Knight's Avatar
Starter switch
[SIGPIC]https://www.vtxoa.com/forums/picture.php?albumid=211&pictureid=950[/SIGPIC]
Knight is offline
post #3 of 7 (permalink) Old 07-19-2012, 01:11 PM
Linies's Avatar
Check start switch, very common to have corrosion on the contacts.
2006 VTX 1300 C
Linies is offline
post #4 of 7 (permalink) Old 07-19-2012, 01:41 PM Thread Starter
THNKYOU FOR THAT.
CAN YOU INSTRUCT ME HOW TO CHECK AND POSSIBLY CLEAN THE CONTACTS?
I'm not very mechanical but am trying - thanks in advance- mike
mlips is offline
post #5 of 7 (permalink) Old 07-19-2012, 01:52 PM
Linies's Avatar
THNKYOU FOR THAT.
Remove the 2 screws on the bottom of the switch housing right hand side of handlebars . take the switch housing apart and clean contacts, should be pretty simple
2006 VTX 1300 C
Linies is offline
post #6 of 7 (permalink) Old 07-19-2012, 01:55 PM
https://www.vtxoa.com/forums/showthre...ls-and-Flasher
POST # 16
Kill switch in RUN position?????
You can also bridge the + battery cable to the starter motor at the relay. MUST BE IN NEUTRAL...
It will have a few sparks---a screwdriver, pliers---across the cable connector...
post #7 of 7 (permalink) Old 07-19-2012, 06:01 PM
mightywarrior72's Avatar
THNKYOU FOR THAT.
Here it is. Also while you are at it, install a relay for your headlights. The problem with the starter switch is that Honda uses the same switch to kill your headlights and start the VTX. When the headlights are shut off for starting, the contacts arc and burn. After some time the contacts are too corroded to work properly. By installing a relay for your headlights, you will eliminate your starter switch issues. PM me if you need additional help.
http://www.rattlebars.com/mtz/starter.html
mightywarrior72 is offline
