1300 Coolant to carb and intake bypass question. - VTXOA
 8Likes
post #1 of 31 (permalink) Old 03-05-2019, 09:15 PM Thread Starter
Phill Reedy's Avatar
Need a diagram, I have searched, the pics from old threads are gone Restoring one with all rotted hoses and wanting to just bypass (I live in a warm area.)
"It's better to step over things that aren't there than it is to trip over things that are." Anthony Wayne Martin.
Phill Reedy is offline
post #2 of 31 (permalink) Old 03-06-2019, 06:20 AM
Welcome Phil from Daytona Beach, enjoy and ride safely.
post #3 of 31 (permalink) Old 03-06-2019, 06:41 AM
Big Al's Avatar
Phil,
I don't know if this helps, but check it out, it is from Honda Direct Line where I buy most of my parts & pieces from.
https://shop.hondadirectline.com/OEM...E1AMEA4E1900DB
“A man can never have too much red wine, too many books, or too much ammunition”
― Rudyard Kipling
Big Al is offline
post #4 of 31 (permalink) Old 03-06-2019, 08:17 AM
the coolant lines are not there for cold weather....
unless you live where 150 degrees are common..
but go ahead.. your bike.
2005 VTX1800 F, type II, Silver Tribal, 88,000 Miles, Purchased Feb, 2005.
post #5 of 31 (permalink) Old 03-06-2019, 11:55 AM
I removed coolant hoses from my carb when changing out the slide valve diaphragm.
One hose has different ID on the ends so that was re-used to do the bypass.
Link below has the hose routing diagram. Coolant heats up manifold also.
A pic of a hose that was cut off and the piece not used. Cooling system diagram found.
Coolant cross-over pipe hose stayed, manifold to carb was old route, now manifold to TEE on return line to coolant pump.
https://www.vtxoa.com/forums/7-vtx-1...ml#post4565022
tworley likes this.
post #6 of 31 (permalink) Old 03-06-2019, 01:21 PM
A_Ninja_Racer's Avatar
I don't want to cause an arguement here. I just want to understand what the porpous is for doing this?
8,000K HID Head Light Conversion, ISO FlameGrips, Kury Turn Signal Mirrors, Mustang seat W/ Driver Backrest, Paladin Backrest/luggage Rack/Saddlebags.
A_Ninja_Racer is offline
post #7 of 31 (permalink) Old 03-06-2019, 02:02 PM
There isn't one aside from not wanting to get the correct hoses.
Donnie Downer is online now
post #8 of 31 (permalink) Old 03-06-2019, 02:55 PM Thread Starter
No need for a circuit to keep my carb from icing where I live.
Yes, they are a carb/intake heater for cold climate. Fuel/air has strong chilling properties and carbs will ice up in cold climates.
That's exactly what I was hoping to do route wise except skip manifold, but wanted to see a flow pattern to be certain it was something that could be done with an expectation of reliability. Thank You!
post #9 of 31 (permalink) Old 03-06-2019, 03:05 PM
<< Deleted >>
post #10 of 31 (permalink) Old 03-06-2019, 05:08 PM
It is for emissions, fuel vapor condensing on cold surfaces becomes liquid. So you need a richer mixture for cold engine to run properly.
Many drag racers have a cool can to reduce fuel temp.
I have not investigated fuel/air density to see what the benefit is.
I had a Nissan truck that I disabled the vacuum valve to reduce air temp(block warm air from exhaust manifold). The carb did begin to ice up, vehicle slowed down.
I restored the vac hose and back to highway speed.. Snowing in South Carolina 1991-92
If I had a free breathing intake with exposed filter I probably would not have done this. I have the stock air box so I do not expect any icing conditions. Warm air from engine side intake holes.
