Fuel Cap - VTXOA
 13Likes
post #1 of 13 (permalink) Old 03-27-2019, 09:05 PM Thread Starter
Fuel Cap
What’s the trick to make the fuel cap latch easier. Meaning key in the cap and trying to spring it back to lock the cap.
Have silicone the key hole and the side prongs.
I have to push in different places now to find the sweet spot to latch.
Use to be easier.
Thanks
2006 Honda VTX 1300S, 9600 Miles, Ultimate Big Boy seat with backrest, several of Glens products.
Wally running lights, LED turn signals, Kury grips, RTB, TPMS.
Progressive Fork Springs, 1800 Rear Shocks.
VTX1300 OK is offline
post #2 of 13 (permalink) Old 03-27-2019, 09:37 PM
I push down hard with all fingers and the thumb.
It was being difficult so I put a few drops of gear oil into the key hole.
Much better after adding the gear oil.
rangers4u and jbrittjr like this.
[B]2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 190,260 VTX miles
post #3 of 13 (permalink) Old 03-27-2019, 09:59 PM Thread Starter
Ok, will try that.
post #4 of 13 (permalink) Old 03-27-2019, 11:30 PM
Use Tri-Flow lubricant. This is the most recommended for you locks on this site. Useful for many other places to lubricate on you bike. You should be able to find it a lot of places locally.
Read thru these posts regarding your problem:
https://www.vtxoa.com/forums/search....archid=2965806
jbrittjr likes this.
Jim Travis is offline
post #5 of 13 (permalink) Old 03-28-2019, 01:58 AM
lofty's Avatar
Not saying my idea is any better or worse but I use a puff bottle of powdered graphite in keyholes when they become sticky
billeng and jbrittjr like this.
lofty is offline
post #6 of 13 (permalink) Old 03-28-2019, 06:16 AM
there are 2 parts..
the key tumblers
the latching arms... spray oil into both arm openings... lay it in its side so excess oil drains on to paper.. not into gas tank
post #7 of 13 (permalink) Old 03-28-2019, 09:03 AM
A_Ninja_Racer's Avatar
Originally Posted by chuck_VTX F View Post
there are 2 parts..
the key tumblers
Yeah I did this and it sounds like this is your problem. I drenched mine in WD40 and then sat there and worked the mechanism a bit. Mine had been sitting for a long time and the cap was a struggle to remove or insert. I also used the Tri-flow on the key side. I let it all sit for a day to dry out and havent had any issues. I also us the 2 thumbs and 2 pointer finger method to insert the cap and get the key ro release.
Jim Travis and rangers4u like this.
8,000K HID Head Light Conversion, ISO FlameGrips, Kury Turn Signal Mirrors, Mustang seat W/ Driver Backrest, Paladin Backrest/luggage Rack/Saddlebags.
A_Ninja_Racer is online now
post #8 of 13 (permalink) Old 03-28-2019, 09:27 AM
for the record.. I have never had this issue...
as its part of a long list of maintenance I do to all my machines..
my motto.. if it MOVES it needs maintenance..... every 2 years.....
from locks.. to driveshafts.... A to Z, 1 to 9,999...... is done
Motorcycles, Cars, Trucks, Lawn mowers, generators,,, ETC.
reason my 'stuff' lasts a very long time.... maintenance... not fix when a problem starts..
prevent problems.. not fix problems.
rangers4u and frnkcat like this.
post #9 of 13 (permalink) Old 03-29-2019, 06:18 AM
Same problem here, pain in the ass to push down.
post #10 of 13 (permalink) Old 03-29-2019, 08:41 AM
Fmkehoe's Avatar
Hey Chuck, you seem like you LOVE maintenance, so who am I to deprive you.
You’re welcome to perform all of my maintenance for me at your convenience. And yes, the beer will flow. &#x1f602;
It's not the speed....it's that sudden stop.
Fmkehoe is offline
