Horn replacement problem - VTXOA
 8Likes
  • 1 Post By TennX
  • 2 Post By TennX
  • 3 Post By Hans&Feet
  • 1 Post By leroys73
  • 1 Post By TennX
post #1 of 10 (permalink) Old 04-15-2019, 05:00 PM Thread Starter
All, I wanted to upgrade the horn on my 2006 1300R and I wanted it to be as plug and play as possible. After reading some reviews I bought the FIAMM Freeway blaster. I hooked it up to the original wires and tested by hitting the horn button. All worked. Then I bolted it on and when I tested it in the end, it did not work. Neither did the original horn any more after I put it back on. I checked and all the fuses are intact. The turn signals also work. Could I have burned the switch using this new horn? Is there a horn relay on these bikes in the circuit? What steps would you recommend next?
Thanks
stasik80 is offline
post #2 of 10 (permalink) Old 04-15-2019, 05:12 PM
I cant help with your problem ,other than to say I used 2 blasters and a relay...the relay is triggered by the stock switch...13 years zero problems...Hans will be along ....good luck
leroys73 likes this.
TennX is online now
post #3 of 10 (permalink) Old 04-15-2019, 05:39 PM
RaginTxn's Avatar
Sorry to hijack, but with the two blaster set up you mentioned TennX - was that the low and high, or just two lows (or two highs)?
Sent from my Pixel 2 using Tapatalk
-R.TXN
Current: 05 Honda VTX1300R
Previous: 13 Yamaha Super Tenere; 99 Honda VFR800i - sold; 08 Honda VTX1800T - sold; 04 Honda 919 - sold; 01 Honda VT1100C - sold
RaginTxn is offline
post #4 of 10 (permalink) Old 04-15-2019, 06:01 PM
Back in the day when I purchased...came packaged 1 high ,1 low.... Nice tone....I did the blasters before I knew about bad boy...
rangers4u and RaginTxn like this.
TennX is online now
post #5 of 10 (permalink) Old 04-15-2019, 06:40 PM
Fiamm Freeway Blaster low = 9 amps(spec sheet). High shows 6 amps
A 10 amp fuse will not handle TS, Brake and Horn.
I suggest you replace that fuse, it may have issues.
You could test the horn at the starter relay battery cable and frame Ground to see if said horns are good.
Relay --yes you need a relay and a 20 amp fuse feeding that horn.
The VTX horn wires are great for triggering the relay..
BobD, leroys73 and RaginTxn like this.
post #6 of 10 (permalink) Old 04-16-2019, 04:13 PM
leroys73's Avatar
As said by Hans and TennX you need a relay.
Two blasters for 10 years with relay. Only two problems: one was mounting the horns securely and the other problem was that I lost one somewhere west of Gallop, NM.
RaginTxn likes this.
My VTX as used on Race Tech site.I'm70 rode 07 Black Cherry VTX 1300R to 49 States+DC & 11 Provinces, 140,000mi+Yamaha RSV,40,000mi,both w/aux tank & Race Tech SuspensionIBA:Mile Eater Bronze &Silver,SS3000,3xSS2000,EclipseSS1000Gold, 20SS1000,6xBB1500,3TX1000,NPT 29/76; Lake Superior Circle Tour 15 to 20K per yr between the two MCs
leroys73 is offline
post #7 of 10 (permalink) Old 04-16-2019, 04:27 PM
I’m going to visit my sister (In the car)...Cheyenne Wy....want me to swing by and see if I can find it...
TennX is online now
post #8 of 10 (permalink) Old 04-18-2019, 12:23 AM
leroys73's Avatar
Sure. As a reward I'll gift it to you.
leroys73 is offline
post #9 of 10 (permalink) Old 04-25-2019, 05:37 PM
I put a will 300-2t on my 07r . it was direct replacement and 125db . I think stock horn was around 75 db . got it off eBay for 14 bucks. It is louder and shaped like original horn
Engineoops is offline
post #10 of 10 (permalink) Old 04-25-2019, 05:39 PM
Sorry, wolo brand 300-2t
