1300 only starts in neutral - VTXOA
  • 1 Post By VTXArizona
  • 1 Post By Hans&Feet
post #1 of 8 (permalink) Old 05-05-2019, 08:16 PM Thread Starter
Just put all new eletrical switches in the bike. Also replaced the clutch plunger switch. Bypassed the kickstand switch years ago. Used to start when in gear. Now not so much.
x2ryder is offline
post #2 of 8 (permalink) Old 05-05-2019, 09:11 PM
VTXArizona's Avatar
Try pulling in the clutch lever. not supposed to start in gear unless clutch lever pulled in.
steveroy60 likes this.
http://imgbox.com/76a6Nr1p
VTXArizona is offline
post #3 of 8 (permalink) Old 05-06-2019, 06:39 AM
if you do not use or want safety switches... just remove them.
aka pre 1970's bikes
Danger,,,,, no safety switches.. can cause bike in gear to launch forward when starter engages .
<< For TEST Purposes Only >>
post #4 of 8 (permalink) Old 05-06-2019, 06:40 AM
Blaine C's Avatar
I do the opposite....I leave kick stand switch operational & disconnect the lever.....That way if you stall in traffic you can start in gear.
Blaine C is offline
post #5 of 8 (permalink) Old 05-06-2019, 09:16 AM
Switch probably not seated correctly since it was replaced...
post #6 of 8 (permalink) Old 05-07-2019, 12:34 PM Thread Starter
it can only seat one way. I've pulled the switch out. Pressed on it with my finger. Still does not start.
x2ryder is offline
post #7 of 8 (permalink) Old 05-07-2019, 12:42 PM
Put a jumper wire across the wire terminals on the VTX and see what that does.
post #8 of 8 (permalink) Old 05-07-2019, 08:59 PM
I forgot about the Kury levers and the issues.
I Googled "kury levers"
https://www.vtxoa.com/forums/7-vtx-1...de-levers.html
Several ways to get it working per above thread.
I am not sure exactly status it is in or what you want.
Thread shows only starts in Neutral..
Here you say will start in gear without the clutch operated.
You bypassed the KS switch years ago, that with clutch switch contacts closed will allow it to crank.
