Shift - VTXOA
post #1 of 2 (permalink) Old 06-23-2019, 07:17 PM Thread Starter
Shift
My 2006 Honda VTX 1300 C won’t shift into 3rd 4th or 5th
Dandridge3 is offline
post #2 of 2 (permalink) Old 06-23-2019, 08:47 PM
When you shift and release the pedal it should return to the previous location.
A ratchet action on the pedal to rotate the shifter drum.
Often the shift pedal just needs cleaning and lube at the pedal pivot bolt.
Hop to it and see if it cures the problem.
If you abuse it then you could have other issues.
Sometimes a spring will break(rare) and the ratchet action will not take place.
You can manually lift and return the pedal.
