Speedometer not working most of the time - VTXOA
  • 1 Post By Capt. Rory
post #1 of 6 (permalink) Old 08-02-2019, 01:23 PM Thread Starter
It works off and on more off though. Dash lights up and odometer is lit but no speedometer or miles added. It has racked up 4.4 miles on the last tank of gas. Tightened battery terminals. Check green connector under tank all seems well. Any other things to check. 1300 r 06
jeffrovtx1300r is offline
post #2 of 6 (permalink) Old 08-02-2019, 03:17 PM
Jack it up and look for pulses from the VSS.
+3 volts to +5 volts, about 70 pulses per rear wheel revolution..
Google this vtxoa: speedo, vss
Primarily a 1800 failure but some 1300 had failures also. Same part for 1300, 1800
post #3 of 6 (permalink) Old 08-02-2019, 03:55 PM Thread Starter
Thank you will check into it.
post #4 of 6 (permalink) Old 08-02-2019, 04:20 PM
I have some info on 1300 Step by Step, more info on 1800 Step by Step due to higher VSS failure rate.
Check voltage and Ground at VSS connector.
Check pulses at VSS connector or at speedo connector.
https://www.vtxoa.com/forums/97-1800...ml#post4548012
https://www.vtxoa.com/forums/attachm...p;d=1532733387
post #5 of 6 (permalink) Old 08-03-2019, 10:33 AM
Earl Riviere's Avatar
My riding buddy had the same problem last year. I had to replace his spedo sensor. It is located behind the coolant reservoir . Easy to replace, just 1 or 2 bolts and a plug in connection. Works great now..
Earl"Tynker"Riviere
62 years behind bars
Earl Riviere is offline
post #6 of 6 (permalink) Old 08-05-2019, 10:20 AM
Capt. Rory's Avatar
You must have the hands of a young Asian raccoon.
VTXArizona likes this.
'04 1300S or at least used to be.
Capt. Rory is offline
