High- Beam Indicator Light fix - Page 2 - VTXOA
post #11 of 17 (permalink) Old 07-28-2015, 10:54 PM
Originally Posted by Mathwiz View Post
Does it matter what direction the color bars are? (Sometimes it does with resistors)
It should not matter with a resistor...A diode has polarity...!!!
SillyOleBear is offline
post #12 of 17 (permalink) Old 07-30-2015, 08:03 PM
But the easiest thing is to paint Wite-out or some fingernail polish on top of the led and the
bright led is muted to a comfortable level.
post #13 of 17 (permalink) Old 08-21-2015, 02:44 AM
NDAna's Avatar
On my 1800 C, I cut 2 squares of printer (copy) paper and placed them behind the blue lens- Just about perfect illumination at night.
Sam/NDAna #15542 IB#38401 '04 1800 C, My LED, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. 4400 lumen H4 LED headlights available [email protected] "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
NDAna is offline
post #14 of 17 (permalink) Old 09-27-2015, 11:32 AM
Hmm. How about a piece of window tint, cut into a circle and allied to the outside ... Pick your shade level.????
Rude dog is offline
post #15 of 17 (permalink) Old 09-29-2015, 09:27 AM
slip's Avatar
This was a definite oversight on the part of the designer. There must not be any kind of diffusing lens over the LED. Most LED's are very directional and the light is concentrated to a small area. They do not have a wide viewing angle. It just so happens that when we look down, the LED light is in a direct line of sight. So anything that diffuses the light should work. I bet a piece of a ping pong ball cut out to fit the hole would work good.
slip is offline
post #16 of 17 (permalink) Old 10-09-2015, 12:54 PM
MRG
I covered the high beam tube on the inside with black tape and put a small pin hole in the tape so I still see the light but is not bright worked out real good for me thanks.
MRG is offline
post #17 of 17 (permalink) Old 03-14-2016, 07:46 PM
roman726's Avatar
Lightbulb High Beam indicator dimming with resistor.
Dimming the High Beam Indicator
Like myself, many of us get bother with the high beam indicator brightness, I read a lot of stuff about shoving some cotton on top or adding some tape or any other mean necessary to block the light.
Well the indicator is an LED so all we have to do is reduce the amount of current being supplied to the LED and that's all.
Hope this helps someone. FYI this is my first How To
Materials needed
1 kOhm resistor 1/4W
Heat shrink
Heat gun
Soldering Iron
Flux
Solder
Needle nose pliers
Wire cutters
Wire strippers
Remove the Headlight
Locate the connector
Locate the solid blue wire
Cut wire
Strip wire ends
Tin both ends of the blue wire and form a hook
Cut resistor leads and form a hook
Attach the wire hook with the resistor hook, place some flux and solder them
Insert a piece of Heat string look enough to cover the resistor and the bare wires
Repeat the other side with the hooks
Slide the heat shrink and heated using the heat gun ( be careful not to apply too much heat and melt the insulation of the wires )
Enjoy you dim high beam indicator
Before
After
2002 VTX1800 R
NSDQ
roman726 is offline
