problem with site - Page 2 - VTXOA
post #11 of 25 (permalink) Old 08-31-2017, 10:34 AM
Capt. Rory's Avatar
Originally Posted by VTXOA admin View Post
Heya all,
You guys can turn off the sidebar to help speed up load times.
The classic view may speed things up again.
Jeff M
Did you even read the post above yours? Are you serious? Just another typical admin response offering no help and only denial of the actual problem.
'04 1300S or at least used to be.
Capt. Rory is online now
post #12 of 25 (permalink) Old 08-31-2017, 12:34 PM
Administrator
VTXOA admin's Avatar
We are not denying the issue.
We are well aware of these issues that are happening.
We don't have much of a solid fix as of yet. So the suggestions JM made are the closest we have to a solution for this issue.
Continue to let us know what issues regarding the slowdown you guys are experiencing.
Richard.
VTXOA admin is offline
post #13 of 25 (permalink) Old 08-31-2017, 12:43 PM
Administrator
^ To add, you can give it a try to see if it improves the speed for you for the time being. If you would like to know how to turn off the side bar (where it shows Recent Discussions, Buyers Guide), do the following:
Go to your User CP (top right corner next to Log Out) > under Your Profile - Edit Your Details > scroll down to last section Additional Information - Show Sidebar on Forum Pages > select Disable > hit Save Changes at the bottom.
Jeff M also mentioned you could try switching to the classic view. At the bottom left corner of every page, there is what's called a Quick Style Chooser. Right now you might see it set on " --VTXOA.com (Full)" select this and a drop down menu appears. Select " --VTXOA.com (Classic Colors) like so:
There are fewer ads and scripts running in that skin/layout so the site should be running much quicker. This is an alternative solution for the time being.
Thank you for your patience and understanding.
Cheers,
Natalie
post #14 of 25 (permalink) Old 08-31-2017, 03:23 PM
Capt. Rory's Avatar
Richard.
You can't really be serious? The links I posted in the other thread have been reported numerous times and nothing has been done about it. A 4th grader with basic coding skill could rewrite and fix this site if allowed access.
If letting your sit go to crap and run everyone away from it you guys are doing a bang up job.
Is this site run by the federal government?
post #15 of 25 (permalink) Old 09-01-2017, 09:46 AM
Administrator
The google analytics link is just that, if it's hanging it's a problem on the end of their crawlers, and static facebook link is present for users that use the facebook log-in and or share, those are the ones I see you referencing, are there others that I miss?
Kyle
post #16 of 25 (permalink) Old 09-01-2017, 10:29 AM
I did some logging with AdBlocker ON = a few lines and with AdBlocker OFF = Many lines.
CTRL+Shift+J = log
I did a screen shot with ABP ON, cropped out blank area.
When I ran it with ABP OFF, it was scrolling its ass off.. Saved it to a text file 11KB.
I went back and saved ABP ON to a text file 4KB.
post #17 of 25 (permalink) Old 09-01-2017, 03:43 PM
Administrator
How long of a load lag did you see with the block off, that report shows 40 seconds total, does that sound about right?
Kyle
post #18 of 25 (permalink) Old 09-01-2017, 06:10 PM
Load lag?????
With ABP off there is constant flow of data. Once in awhile a slight pause and more data streaming in..
A few more files to peruse.
With ABP ON, all quiet after 11 seconds. and a few more lines later within the minute..
Sometimes I have gotten quicker on the trigger to start the data logging.
post #19 of 25 (permalink) Old 09-02-2017, 06:47 AM
Capt. Rory's Avatar
Kyle
So in other words this will never change and the site will never run smoothly unless it happens to one of the rare days that those two links are not hanging. There are a couple other links that are slow at times, but the two mentioned above consistently hang.
So even if you don't do Facebook it still gets to cause you grief, thanks a lot.
post #20 of 25 (permalink) Old 09-06-2017, 11:22 PM
OK, it is somewhat better tonight but still not like it was. NO changes made on my end.
Jim Travis is offline
