Where to start? four days ago I went out and about a minute from home the bike started to sputter, miss and backfire. Within 30 seconds the front cylinder had gone dark and I had to limp her back home on the rear only. The rear was as strong as the front one was dark. Getting her back I started checking the usual suspects, battery connections, spark plugs etc. to no avail. The next day I swapped the front plugs to the rear and tried to start her. At first it was only the rear cylinder again, then a few seconds later the front began sputtering back from the grave and within 30 seconds, she was running as clean and regular as ever she had. Shut her down and started her again.... several times. Every time she fired right up and sounded great. (Yes, an intermittent failure, just great.) Shut her off again and got my wallet to go get some gas and when I fired her up again, she was once again only liking the rear cylinder and the front was dark once again. However, this time it compounded. within a minute the rear cylinder began to miss and backfire and in short order, it to went dark. Any attempt to start her after that has failed miserably.
She has such a weak spark and 90% of the time I can't even see any spark.
Now absolutely everything else works fine.
As of this moment I have performed the following checks and procedures in search of the culprit.
-Checked fuses, including the two 30amp mains on the left side to the rear of the starter solenoid
-Checked gas and swapped it out
-changed plugs
-checked the grounds, (did the full ground fix 7 months ago)
-Disconnected my PCIII and checked the TPS wire for any damage where the PCIII is piggybacking the wire. (Soldered and sealed with no issues)
-starting in the headlight bucket and working my way back, pulled, checked and reconnected with di-electric grease, every connector I could find.
-Traced and tested continuity in wires from and to the ECM for the Camshaft position sensor, Crankshaft position sensor (Ignition Pulse Generator), Coils, Injectors.
-Tested fuel pump pressure
-checked for fault in fuel pressure regulator
-checked resistance of Primary coil windings, both within the 3-4 ohm range.
-Checked resistance and possibility of short in the secondary coil windings
-Swapped the ECM with a friend
disconnected and checked resistance/continuity of Crankshaft position sensor
-Checked for same resistance reading at the ECM connector
All to no avail. Nothing found to be amiss anywhere yet. Still, no spark.
Am building a Peak Voltage Adapter for my multi-meter tomorrow and then test the output of the Crankshaft Position Sensor and coils.
Any and all help with this would be greatly appreciated.
-changed plugs
