Old brake fluid could be a cause. Been parked for awhile?
Push on the caliper with your knee and see if you can back up the pistons.
Bleed the brakes..
Disc brakes drag, turn your car off in neutral and push it, you'll hear drag. How much is the question. If your rotors are too hot too touch, that's too much drag. When was the last time you cleaned the pistons and glide pins and greased the pins?
