'08 problems
204 Views 7 Replies 5 Participants Last post by  Hans&Feet
my name is stosh, i have an 08 (sold an '02 last fall), both have identical problems. took the fuel rail apart on the '02 (found nothing), changed spark plugs-no difference. Both bikes have intermittent speedometer problems (no indication of either speed or odometer). now the '08 has ZERO speed (and mileage) indications. the FI light comes on after i ride the bike for about a 1/4 mile (no FI light when the kickstand is down, idling below 5000-in my garage). when the light comes on I can feel a decrease in performance (bike does not stall, act erratic, nothing). I can clear the light be turning the bike off and on (I have gotten quite used to this while in motion)
any help???????
any help???????
Sounds like the ground fix is in order. TONS of info about it on the forum. First check your battery. If that's good, search "1800 ground fix" and get comfortable. It isn't a hard fix at all, but a very necessary one.
Reactions: 2
i have had this problem for a while now......................i looked last year (when i still had the '02) and the DIY said to check the 3 grounds. i did 2 out of the three on the '08 bike(maybe its in the third one?!?)
Reactions: 1
Maybe. The ground under the tank, next to the front coil, is the electronics ground. It needs to be done every couple years depending on your climate. You have to keep up on it, it isn't a one-and-done thing.
Reactions: 4
Start from square 1: Make sure you have a fully charged battery, then take it to an auto parts house that will do a 100 amp automotive LOAD TEST to determine how good the battery is. Once that is proven, move to the 'ground fix'. And let us know.
Reactions: 3
The VSS outputs +5v pulses per service manual, usually 3.7 volt pulses.
1800 VSS, a few fail every year. Any MIL codes??? Code 11 = VSS failure
The severity of the signal can cause a "limp home" to protect the engine.
2nd Generation1800 has an improved Ground system.
Battery Negative to engine case. Cable from Starter motor bolt to a bracket on the down tubes.
Common Electronics bolt at the Frt Ign coil. Clean and lube.
Reactions: 1
Huh
Are you a scammer???
There is a "New Member" board for "New members".
Do the right thing, if not then you are a scammer.
Besides that you also hijacked a thread. HUH
Reactions: 2
