Worked today on valve adjustment, but I couldn't get the airbox off....the 10mm bolt just spins....looks like there's a nut embedded in rubber that is just spinning with it. Anyone run across this or have a solution? Thanks.
I had the same problem as has many others. Unfortunately I can't remember the remedy. I had another problem with my bike and I had my mechanic fix it. It is a chronic issue. There was someone else that posted this question about a month ago. You may be able to go back and find the answer posted.
You should be able to remove the other screws first and then pull on the air box toward the front or back to put pressure on the nut. And never tighten that one more than snug. Mine was like that from the factory too. I did the above and used an air impact to get it off and it came off immediately. Good luck.
I did the same thing a few weeks ago, nothing worked for me and I tried the air impact too. I finally pulled the top part of the air box away from the frame and was able to complete the valve job.
I used a 10mm socket on a long extension to hold down the rubber grommet from the left side of the bike while I loosened the bolt, screw driver would probably do the samething.
Did my valves again today for the heck of it no problem with that bolt , you guys just dont know your own strength. :lol: Im glad I read about this problem early on , so I just snug mine up each time , its really more of a compression thing as opposed to gorilla tight. have a good one
In case there are others still facing this issue today - my story is had a friend who bought an OEM air box to replace the high flow air kit on a stock bike that had no JetKit to match it. She wasn't willing to spend more on the bike so she found a cheap used airbox online, but it came from a crashed bike and seems the 10mm bolt was seized on the rubber coated brass threaded base. After much deliberation, and considering since she already had this grommet still on her bike, I simply used a pair of needle-nosed lock pliers, and slowly used a 10mm socket with an extension from the inside. Came out within minutes. If you don't have a spare grommet to destroy, as some have stated, this can be had at any Lowes/HDepot and for the purists out there, myself included, I think it's like $10-$15 at a stealership.
