1 - 20 of 27 Posts
Sorry, I really did try and get this info from the archives but couldn't find it. I currently have a 1300 final drive coming for a swap on my 2002 1800c - it's shipping with the pumpkin and a drive shaft. My question: does the swap require both parts or are the shafts the same on both models? Thanks!
It pops right in. Unless your shaft was damaged, leave it off for the swap.
2003 VTX 1800S, 2010 Goldwing, 2009 Spyder GS
I’ve been told the 1300 on the 1800 drive makes for better RPMs at highway speeds, less looking for 6th gear. I wouldn’t mind trying it myself some day.
Reactions: schnitz
2003 VTX1800R
I wouldn't mind doing that myself. I just went with a lower profile tire (180-60-r16 instead of the stock 180-70-r16) and would like to get my RPMs back below what it put the engine at. I've been working toward getting the bike down to where I am comfortable with the height. It's pretty good now, but I'm still going to install air ride in the back.
Reactions: rangers4u
2002 Honda VTX 1800 C
Yep, in effect you geared your bike down with a smaller tire diameter.
2003 VTX1800R
I have found 1300 differentials for sale and they are pretty in expensive. I think I'll get one. If I like it then great and I can sell the 1800 differential. If I don't then I can reinstall the 1800 and sell the 1300 differential. I think I'll be happy with the 1300.
Reactions: schnitz
How much do they sell for? The ones for a Valkyrie, which are on the right side (they call them pumpkins), sell for around $500 used. What Valkyrie guys normally do is rebuild them but that is one can o’ worms I would never open 😊
I read somewhere on this forum that the final drive gearing is different on a 1300, isn’t it a little taller than the 1800’s?
1300 - 2.8
1800 - 3.1
2003 VTX1800R
I was just looking on eBay and found several below $100 and a few just over $100
Overhauling a drive unit (diff.) is really not that difficult. But you don't need to. It seems there are 13 drives to be had with relative ease. I have been running the 13 final for MANY years and tens of thousand miles. I would never switch back. But, I do 90% of my riding one up. And most of it is out on the road stuff. Was never a big stop light to stop light guy (though it can sure be fun). I've always liked running out the gears. Easily over 100 mph (indicated, stock speedo) before banging 5th. I kept my 18 final. Probably has about 20,000 miles on it. Don't expect a HUGE difference but, it does change the nature of the bike a little..
Should of been that way from the beginning ❗
I don’t know, I like the way my stock 1800 is geared, but I don’t have anything to compare it to. On another thread they’re talking about clutches slipping — I tell you, mine doesn’t slip and the bike rockets from 50 to 80 mph in about 2 1/2 seconds LOL
2003 VTX1800R
It’s late and I’m OCD so bear with me. LOL This is for the 1800R and these are the calculated speed differences between 1800/1300 gear, the 70 series stock tire and the 60 series I put on it.
1800 gear with 180-70-R16 and 180-60-R16
Font Screenshot Gadget Electronic device Games
Font Screenshot Electronic device Gadget Terrestrial plant
1300 gear with 180-70-R16 and 180-60-R16
Font Screenshot Electronic device Terrestrial plant Circle
I think I’ll be pretty happy with my lower profile tire and the 1300 gear. It puts the speed output closer to factory with a slight highway advantage which is where I spend most of my time riding.
Reactions: DrDolittle
When the VTX1800 came out in 2002 it was the largest displacement production V-Twin in the world.
It was a hotrod. The lower gears made it a little quicker in a drag race situation.
Similar to the old 60's vintage muscle cars with a big block, 4-on-the-floor, and a lower gear ratio differential.
I've been running a 1300 FD for years, and I like it better.
Discussion Starter · #20 ·
I received my 1300 final drive and have been cleaning it up. Looks like it's in really good shape, just a few little marks. It seems very similar in looks to the 1800, what can I check to confirm it's a 1300 final drive?
1 - 20 of 27 Posts
