My 06 1300C has been perfect until a few days ago. During a PGR mission, the headlight and driving lights on the light bar would go on and off intermitently (the turn signals on the light bar and the tail light continued to work). Also, at one point, the electric start wouldn't work, but has worked since then. A friend said it may be a grounding problem. If anyone has any ideas/experience with this type problem on a 1300C, your help would be greatly appeciated.
I haven't seen much if anything on the 1300 board regarding a ground fix. It does sound like you have a bad ground in your light bar, and the switch problem is probably coincidental timing. they are known to pose issues. there are quite a few posts regarding the start switch acting up.
At the risk of sounding redundant.... I also think starter switch. That link W9VD provided will be extremely helpful.
