1800 » Lighting/Electrical/Wiring
How to wire a Kuryakyn lightbar (part# 4001)
For reference here are Kurys (poor) instructions: http://web.archive.org/web/20061025114833/http://www.kuryakyn.com/documents/installation/4001-22GL-0204.pdf . Lets do this one part at a time, first the blinkers... Your bar has 3 different colored wires coming from it, red, white and black. There is a set of these for the right side and a set of these for the left side.
On the left side you will wire:
Red wire from Kury bar to orange wire with white stripe on the bike.
White wire from Kury bar to orange wire on the bike.
Black wire from Kury bar to green wire on the bike.
On the right side you will wire:
Red wire from Kury bar to light blue wire with white stripe on the bike.
White wire from Kury bar to light blue wire on the bike.
Now with the turn signals on the bar wired well wire the foglights... These lights get their ground through the mount to the bike so well only need to put power to the BLACK wires on these to make them work. For EXCELLENT info on wiring fogs you can go here:
http://www.rattlebars.com/mtz/foglites.html
Here is a diagram from Chet that shows EXACTLY how you need to wire these lights:
The only difference is that the red wire going to the lights will be the black wire coming from the lights now. Using the Kury wire harness (which IMHO is a ripoff since you can make your own for much less, but to each their own!) this is what well do.
Kury harness directions are here:
http://web.archive.org/web/20061025114833/http://www.kuryakyn.com/documents/installation/2328-21HD-0503.pdf
From the plug on the Kury harness:
White wire (with ring terminal) on Kury harness to the bikes battery + (positive) terminal.
Black wire (with ring terminal) on Kury harness to the bikes battery - (negative) terminal.
There are 2 white and 2 black wires bundled together - you will wire the 2 black wires to any good ground on the bike. I dont recommend wiring it to the green (ground) wire in the headlight only because youll overload it. You can ground these wires to any bolt on the lightbar or pretty much any bolt on the bike. The point is just get these 2 black wires grounded. The 2 white wires will go to each spotlight on the lightbar. One white wire (from harness) to one black wire (from the spotlight) on each side.
From the switch on the Kury harness:
Red wire on the Kury switch to the blue wire with white stripe located in the headlight on the bike. Pay close attention when routing these wires and snugging everything down, a bunch of guys reported pinching wires on these harnesses early on causing the lights to short out and blow fuses.
More information:
http://web.archive.org/web/20061025114833/http://www.vtxoa.com/forums/viewtopic.php?t=28298&sid=d60354c08423f980e505ae4f54d21b6e
Last update: 2004-11-10 11:56
Author: Bareass172
More information:
Author: Bareass172
