I'll try this again, posted in the wrong section before.
I tried a search for info, but nothing came back. I'm wanting to change to a dual exhaust system. I don't like the single look. Are there issues with fitting? Performance? Or any other problems to consider. Thanks for the help
Do you want 1800 R/S mufflers or aftermarket pipes? R/S require that bracket also.
No major issues, another hand or person to help hold them in place while assembling.
You can get exhaust gaskets from a dealer or look at compatible gaskets on a list in the Step by Step.
Here is one aftermarket seller.
http://www.hardkrome.com/models.php?modelID=16
If you put stock R/S on a C model, you will melt the side cover. So you would need both the side cover and the R bracket. If you go aftermarket, just be sure they are made to fit the C model like Vance&Hines Bigshots. They are 2into2 pipes and are one of the best performing exhausts on the 1800
I did not know that side cover clearance was an issue!
Thank You Larry!
Yeah, the R models have a cut out for the rear pipe as it goes over the clutch housing and the C models the rear pipe goes forwards and wraps under the clutch so it is shaped different ;)
