KyHillBilly said:
1. What are the oil viscosity requirements for the 1300
2. What are some good P/N's for Oil Filters (Different Manu's)?
1. Oil viscosity requirements are as follows (Most are running 10W-40 or 15W-50)
15º - 90º F - 10W-30
15º - 100º + - 10W-40
25º - 100º + - 15W-40, 15W-50
30º - 100º + - 20W-40, 20W-50
2. Here is a filter cross reference - I recommend the Bosch 3323 as a good alternative to the OEM Honda filter.
From the net
These motorcycles all use the same spin-on filters with 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, gasket diameter approximately 2.3 inches, O.D. approximately 2.75 inches, length approximately 2.5 to 3.5 inches. If your bike has a lot of room around the oil filter, I suggest the longer models.
Automobile Filters, about 2.5 inches long
• Mobil M1-108, about $12.
• Purolator Pure One PL14612 about $6.
• Bosch 3300 about $6. About 64mm, doesn't quite fit oil filter wrenches. A real pain.
• WalMart SuperTech ST6607 about $2. Made by Champion.
• AC Delco PF1237 about $6.
• NAPA Gold 1365 about $6.
• Purolator L14622 about $4.
• STP S-02876 about $3.
• Baldwin B1400.
• Hastings LF113.
Motorcycle-Specific Filters.
• AC Delco PF2135 about $10.
• AMSOil SMF103, about $9.
• FRAM PH6017A about $7.
• Honda 15410-MCJ-000, about $12.
• K&N KN-204, about $13. Has a metric nut on the end for easy removal.
• NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8.
• Purolator Motorcycle ML16817 about $6. Imported, not made by Purolator.
• STP SMO 07, about $7.
Automobile Filters, about 3.25 inches long
• Bosch 3323 about $6
• Mobil 1 M1-110 about $10
• Purolator Pure One PL14610 about $6
• Purolator L14610 about $4
• NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
• Deutsch D-370 about $4
• AC Delco PF-2057 about $6
• Motorcraft Long Life FL-821 about $4
• STP S-02867 about $3
• FRAM, Castrol, Penske 7317 about $3
• Baldwin B1402.
• Hastings LF240.
