Any reason you decided to keep the position/run light on while the TS is flashing??
Honda turns off the run on the side that is flashing for better contrast.
Now you have bright for TS and less bright for run when TS is flashing..
Just wondering...
If you removed the bottom diodes, and cross connection you made to those diodes, remove the resistors then
you could have Bright running lights and the bright TS and let the Honda TS switch remove the run power on the LED that is flashing.
I forgot to mention---nice drawing!
