None!
Although manufactured starting in 2001, they were designated 2002 models. I have an early one at number 487. I'm thinking it was built in April or May of 2001.
Woot!
2001vtx
woot, hi, mine has a manufacture date 05/01 but title is a 2002 where did you get the number? tom
It's part of your VIN number. Manufacturing started in 01' as 2002 models. Same thing auto makers do. Cars come out in Aug/Sept 08 as 2009 models.
Here's a way to read the VIN
Deciphering the VIN# on the VTX
Original info from Biglry - taken from the VTX parts catalog
We'll use the VIN # from my 2002 1800 C
1HFSC46042A006692
The first three digits are the world manufacturer identifier (WMI). This tells the make and type of vehicle
Mine is 1HF
JH2 = Honda motorcycle (Manufactured In Japan)
1HF = Honda motorcycle (Manufactured in USA)
YC1 = Honda motorcycle (Manufactured in Belgium)
9C2 = Honda motorcycle (Manufactured in Brazil)
3H1 = Honda motorcycle (Manufactured in Mexico)
VTM = Honda motorcycle (Manufactured in Spain)
ZDC = Honda motorcycle (Manufactured in Italy)
JH3 = Honda all terrain vehicle (Manufactured in Japan)
478 = Honda all terrain vehicle (Manufactured in USA)
The next five digits are the Vehicle Description Code (VDS)
Mine is SC460
SC461 = VTX1800 CA
SC460 = VTX1800 49st
The next single digit is the check digit. This code is used to detect errors in the VIN and consists of a single-digit number or a letter (except I, O, Q, and U)
Mine is 4
The next number is the model year
Mine is 2
B = 1981
C = 1982
D = 1983
Y = 2000
1 = 2001
2 = 2002
The next letter/number tells the plant the bike was built in
Mine is A
A = Ohio factory in USA
B = Aalst factory in Belgium
C = Saitama factory in Japan
D = Guadalajara factory in Mexico
E = Montesa factory in Spain
F = Atessa factory in Italy
K = Kumamoto factory in Japan
M = Hamamatsu factory in Japan
R = Manaus factory in Brazil
S = Suzuka factory in Japan
T = Tochigi factory in Japan
4 = South Carolina factory in USA
The last six digits are the sequential production numbers, also known as the Vehicle Indicator Section (VIS)
Mine is 006692 so I know based on my VIN# that it was the 6,692nd bike made at the Ohio plant in 2002
Any change or modification of parts is directly related to the VDS and VIS.
a VIS number will appear in the "Serial #" column of the parts catalog if a part is changed or modified.
