1 - 16 of 16 Posts
I just changed my plugs 2000 miles ago and my bike it starting to act like it was before I changed my plugs. The bike run rougher at times and smell like gas when idling, smell worse after the motor is has been running a while. When I removed the old plugs 3 where black/wet and one would have been ok. Someone told me that these bike came from the factory with too short of ignition wires, anybody heard of that?
Umm, nope. What is the part number on the plugs you're using? If it's the IFR6L11 then you should go up one heat range to the IFR5L11 as this plug is in the 2003 VTX's to combat plug fouling. You should also be running 87 octane fuel, any higher and you're only adding to the fouling problem as the VTX was designed to run on 87. You should also tighten up your battery cables and do the ground fix paying special attention to the "Common Electronics Ground" section as seen on the VTXOA Garage site http://tech.vtxoa.com
Welcome to the board!
Bookmark or save to your favorites folder, these websites, http://tech.vtxoa.com This is the VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://www.vtx1300tips.com/ another fellow VTX Riders site.
There is also a helpful red Search icon at the top of every page(not the Google search)
Search Query section
Search for Key Words;__________________________
Below that click on the "Search for All Terms" button, effectively unchecking the default selection of "Search for any terms or use query as entered"
Search Options section
Now that you have a list of threads you've searched for, do not just click on the thread you want to read. Instead RIGHT click on the thread and select "Open in New Window" This will pop up a new window with that thread in it, leaving your searched list intact for you to go back to.
Also, update your Profile to include where you live and what type X you have to your Signature line. I.E. 1300/1800/C/F/N/R/S.
The 2002 bikes came from the factory with cooler plugs than the later years.
You shoould be running NGK iridium IFR5L11 plugs
or NGK BCPR5EP-11
The IFR 6 series plugs are cooler running and
IFR 7 series is even colder.
or DENSO VK16PRZ11 plugs.
The VK 20 series is cooler
and vk22 series even colder
Some folks are happy running Bosch Platinum 4 4419 plugs
but most folks running Bosch plugs prefer the 4418 plugs
I would avoid using Champion sparkplugs no matter how low they
might be priced. Their quality control is terrible.
I have had electodes break off the plugs and
even had the ceramic insulator blow out of the center of the plugs.
I will never use Champions again.
Hotter Plugs
I have actually when to a hotter plug, it solved the problem but now it is coming back. When I start it if I give it a couple shots of gas it backfires and last time out, it backfired a few time when downshifting to stop at street signals. It also did the same thing witht e original factory plugs, my bike only has 8,000 km on her.
Check the fuel pressure regulator. I've had good results with the 4418's myself and I rotate them when the bike starts to get sluggish.
Just Changed plugs
Changed out plugs to 4418 will have to see how they work out. One thing to remember make sure you use anti seize on them
:yikes:Don't be a dumb azz like me and put electrical grease on them coz I didn't read packet first:yikes:
I have been running the stock plugs in my 2002 retro and I have had no problems with fouling, I changed the first set around 8000 miles and the second set is still going @ 11,000 miles. You may want to check your fuel pressure regulator
Along with defective fuel pressure regulators there have been problems with the fuel return hose from the regulator back to the tank. If the hose is kinked or restricting fuel flow in some way it may cause excessive fuel pressure to the injectors.
Why would you say this ?? If the cross reference tells you to use the 4419 for all bikes except the 2002 .
I have used the 4419 since the first plug change and am very happy with them . Most folks do not prefer the 4418
or NGK BCPR5EP-11
If I remember correctly, the 4419 is a hot plug, the 4418 is the stock plug and the 4417 is a cold plug. There's about a 70 degree combustion chamber temperature difference between the 4419-4418 and the 4418-4417.
This would be a good place to look to make sure you remember correctly
http://www.bareasschoppers.com/plugs/
The 4418 would be the proper plug for a 2002 only. The 4419 is the proper plug for 2003 and later ..the 4417 has never been mentioned as proper to use in the 6-7 years i have been reading this forum.
In the 2002 model some of us did have fouling problems and by 03 a lot of us with 2002 bikes were already running the 4419 plugs.
Then someone noticed that 03 bikes were coming with a hotter plug and when it wass cross referenced it was a 4419.
I see no reason to ever use 4417 or 4418 as honda does not use that cold of plug in any vtx1800 since 2003
the other good question would be is your bike stock??
any airbox and pipe mods????
do you have a PCIII installed??
these questions can also be a factor..if none of above..then as previous..
change out the plugs and stick to 87 octane ...it should help..
how about the ground fix?
now I see everyone talking about the plugs, but wasn't there a ground fix that would help, so that you wouldn't miss fire and cause the foul plugs? Maybe first check and see if you have done all the ground fixes first. That may help some of the fouling.
It is the fuel pressure regulator
Just changed mine, same problem you were having, bike runs perfect! Very easy fix, thanks to this forum!:thumbup:
1 - 16 of 16 Posts
