1 - 2 of 2 Posts
my vtx1800r master clutch cylinder had started to leak fluid so i purchased a rebuild kit from K & L. I replaced it exactly as i should. My problem now is the Cylinder will not Prime so it will not push the slave cylinder. When i bleed it fluid does pump out of the bleeder valve but no pressure to the slave. I have checked the Slave cylinder for leaks but there are none. Any Tips that could help???
Air bubble in the banjo fitting? Squeeze lever and loosen banjo, see if air comes out. Pumping fluid up has the best chance of moving air bubbles up. Leaning on KS may hold bubble.
1 - 2 of 2 Posts
