1 - 3 of 3 Posts
I have to tap in to a light bar that I purchased from Walmart to get my headlight to work. For some reason the wires leading to the switch are not pushing power. Also I have a yellow and brown wire in my my headlight housing that is loose. Any thought?
oh no, not another dirty head light switch...
15 years of preaching ... clean it every 2 years.
I have been wrong before,,,,, and will again..
Yellow could be the Tach wire if you have a 1800C.
You have to provide the model and year. Signature line is a great place to plant it.
Most wires have stripe, 2/3 primary color and 1/3 stripe.
Examine carefully. Some color combinations bleed some since they are old.
The headlight wiring goes through the Starter Switch, it frees up about 5 amps when the engine is cranking.
The constant headlight current starts heating up the switch contacts after dirt and grease get older.
Starter switch cleaning>> Look at Step by Step, also has a 1800 section
https://www.vtxoa.com/forums/73-how-step-step/456068-rattlebars-starter-switch-mtce.html
1 - 3 of 3 Posts
