1 - 12 of 12 Posts
When starting to lean the bike in a curve I feel what seems to be a grinding or a vibration . Is this normal if the tires need to be replaced or is it possibly bad bearings ? If its the bearing what is the easiest way to check them ?
I have the same thing with only 1000 miles on a 2003.
It seems the worst within the first block or two. Flange bearings???
StockStinks.
I feel the same and have on all of my X's.....
I've never felt a vibration or a grinding noise on mine.. :pepper1: :beer3:
I was told it was my tires were making this noise and vibration.My tires are worn out now and I have a set of Bridgestones coming so I'll find out if that was it.
I've noticed this on mine during the last 1000 miles or so. Even happens if you just lean the bike to one side or the other slightly (doesn't have to be a 'curve'). I've been trying to figure out whether it is a problem with some type of bearing that is wearing out or if it is a tire issue. If anyone has solid info on what it is or what types of things to examine I'd appreciate it!
Rob
I've had it happen twice. Both times were the tires. Mine are bad enough now that they squeel in a tight corner. Just waiting for another set a Bridges to get here
Les
it sounds like tires,get the feel of the road,with no vib,just lean the bike over a litte bit,if you get your vib.its tires,
ride safe
ride safe
I'd put my money with john especially if you are running the stockers or avons or Bridgestones and the like on the front, which have a center tread groove and more agressive tread on the outer edges of the tire. As you lean, you roll onto that agressive tread section and get a buzz, vib, grinding sort of feel. I've had this with all the tires mentioned above on my scoot.
Mike
Mine is doing the same thing. I am on my second set of tires (Metezler) and mine did it with the dunlops also just worse. Checked the bearings and drive train and all is good. Sooooo it must be a normal condition with the X. :?
It's the tires, a flange bearing will not cause a vibration as there is little to no weight on that bearing. They are pilot bearings only, the bikes weight is on the wheel bearings.
The tire wear that causes the vibration and sometimes noise is called tire cupping, read this;
http://www.rattlebars.com/valkfaq/tirewear/
ride safe
This matches my observations exactly. That makes me a bit 'happier' that it is probably my tires and not a mechanical problem. I have almost 6,000 on the stock tires so this probably makes sense that it's my time.
Thanks!
Rob
1 - 12 of 12 Posts
