41 - 54 of 54 Posts
Discussion Starter · #41 · (Edited)
190,763 miles; 5/20/2019
#41 Oil & filter change: Mobil Delvac 15-40/ Purolator L14612; completed install of new Rick's stator and new Shindengen SH775AA R/R
Discussion Starter · #42 ·
192,635 VTX miles, 7/25/2019 Final Drive Gear oil changed. 6oz out(measured),
6oz in (not measured, X on the jack, vertical position, turning rear wheel while stinky stuff running out of fill hole)
I decided to forego the Moly paste this time.
Discussion Starter · #43 ·
195,759 miles. 3/20/2020. #42 Oil & Filter chg. Chevron Delo SDE SAE 15-40 Purolator L14612
Oil leakage found coming from Exhaust valve adjustment port cap. O-ring is flat.
Oil drained down to kick stand side of cylinders for the most part, but some oil ran straight down and dripped onto the lower fins..
The o-rings were from ACE replaced in May 2015 at 162K miles. Maybe under-sized...
I went to Honda Dealer, no "91303-KK3-830" in stock. Counter kid said would have to lookup the 12mm aluminum drain plug washers. BYE!
NAPA had the alum washers, HF had a box of o-rings. I put on one 35mm o-ring, a little fat. Honda is 35x3 HF is 35x3.5
Will see how this fat mama works! The other 0-ring replaced.
I used some degreaser and water hose pressure to rinse. Looks good.
Great detail Hans. Thanks for posting.
Simply impressive Hans. I keep a written diary since I bought mine (used) in May '09 (4456M).
Anybody tell you that you do good work ??? (y)(y)(y)
Discussion Starter · #46 ·
I wish I would have created a daily ride log.
2007 I have only one ride in my "MC Rides" folder. Hal's ride Asheville to Chimney Rock > Lake Lure > a gas stop in SC > I bailed out in Brevard, NC. I was next to Kevin for awhile and his de-cel explosions were killing me.
Reactions: SUMDATX
Actually, I keep the same kind of records for all our vehicles, since I do all the maintenance anyway. Traded in the wifes Murano last year for a Subaru Outback. Gave them my notes to go with the Murano and they said this is like gold. I guess so since it keeps you off a trail already traveled ;)
Discussion Starter · #48 ·
Thanks for the reminder! I forgot to add last vehicle oil change.
Reactions: SUMDATX
Discussion Starter · #49 · (Edited)
After a 50 mile ride, oil change time.
201,100 miles; 11/28/2020 #43 Oil & Filter chg. Chevron Delo 400XLE
15-40 Synthetic blend Diesel Engine oil.
Purolator L14612 oil filter.
Discussion Starter · #50 ·
201,897 miles, 3/18/2021 New Yuasa YTX14H-BS installed.
A few weak cranking events with15-40 Dino oil, since upgraded.
A few times over the winter old battery placed on low current charger that tops out at 13.9 to 14.0 volts.
Old Yuasa battery moves to lawn mower service, 14hp B&S.
Discussion Starter · #51 ·
New tires on the X.
14th FRT-- 204,191 Bridgestone Exedra 9/30/2021 DOT CJ6D (PEC5120)
18th REAR tire -- 204,191 Bridgestone Exedra 9/30/2021 DOT ENXD (CAN4020)
Front tire wobble for past 1.5 years, suspect a pothole caused it.
OK when tire warmed up after a few miles.
New Bridgestone tires seem to be good. I have to check air pressure, it could be too high.
Curvey Girl valves installed. $60 to Mount & Balance tires
Reactions: MR VTX
Discussion Starter · #52 ·
12/26/2021 204,638 miles. Rear Brake problem, no braking. No fluid when bleeding normal method.
Pushing on brake cylinder to retract the piston broke loose the blockage with 25 in vacuum.
3.5 year old fluid.
3.5 year old fluid.
That's a long time for brake fluid to be in there...shame on you. :p
Discussion Starter · #54 ·
11jan2022 204,709 miles
Frt brake fluid replaced.
Effort to stop now requires less pull strength.
41 - 54 of 54 Posts
