Shocking as in suspension that is.
Bought a used '05 1800C w/ stock suspension and it is a HARD ride. I've tried all 5 rear suspension settings and it is still too HARD! I've read lots of posts re: Progressive front and rears. Do I need to chang out my stock stuff all the way around or will fronts alone do the trick? I'm 5'11'' and 190 lbs. What do you guys suggest? If you think I should change out all the way around, what model? 412's?
Joe
Fronts will only stop the front end drop really and offer better handling. The rears are what carry most of the ride quality factor so if you are wanting a smoother/softer ride, you need the rears too
I'm about your height and weight, and I have to say it is a hard ride for me too. Getting progressive rears helped some, but not much. I would actually recommend NOT going to the progressive front springs. They have made the ride even stiffer. I might go back to the stock front springs.
