1 - 1 of 1 Posts
2006 HONDA VTX 1800S Spec III “American Trike” Conversion, Loaded Trike
9K miles, Reverse, Batwing Fairing w/ Audio, Crash bar w/ adjustable vent Lowers, Raked Front End, Memory Foam Seat, Leather Top Box, Rack, Hitch, Light Bar, and Chrome Forks.
(VTX) – V-Twin Extreme Buckets of chrome and everything about the VTX1800S says classic, old-school cool.
The Raked EZ-Steer triple tree adds 5+ degrees to the stock rake (it’s like having power steering).
The reshaped Memory Foam Seat (by Mean City Cycles) has you sitting comfortable and low at 27 inches.
Rear wheels have genuine Moon Eyes brand hubcaps.
Engine/ Drivetrain
Engine is a 1795cc liquid-cooled 52 deg. V-twin that pounds out enormous power – 106 horse power and 120 lb/ft. of torque.
The result: muscular power across a broad rpm range for unequaled acceleration and roll-on performance.
- Single Overhead Cams
- (SOHC) Ignition: Digital with three-dimensional mapping
- Two spark plugs per cylinder.
- Cooling system: Liquid
- Gearbox: 5-speed Transmission type
- Final drive: Shaft drive.
The VTX brings a new level of sophistication with a PGM-FI electronic fuel injection system.
Engine upgrades: fuel injection management system, Spike air cleaner and pair valve modification.
Spec 3 Custom-Building Options
- Crankcases, cylinder, starter motor: Satin black finish with milled cylinder fin edges.
- Handlebar: Chrome-plated cast-aluminum handlebar risers and caps.
- Clutch and Brake Levers: Highly polished aluminum finish.
- Fork Tubes: Chrome steel covers highlight detailed front end.
- Upper and lower triple clamps: Highly polished cast-aluminum.
- Radiator Cover: Chrome side cover.
- Floor boards: Polished and chrome-plated aluminum.
- Final Drive Housing: Hairline stain brushed with chrome plated axle caps and fastener.
- Satin-finish cast aluminum wheels.
Batwing fairing with marine 300 watt Pyle audio - Bluetooth: send and receive calls, Am / FM, SD / USB player, and Aux inputs.
The fairing also has secondary displays with a GPS speedometer, as well as all tank mounted indications.
Storage: Leather tank Bib, Large storage in Trike trunk, Harley Top Box with little saddle bags and Harley lower fairings and crash bar. The Top Box and Trike Trunk have storage compartments that are lockable and perfect for keeping extra riding gear or securing valuables.
“American Trike” Conversion”
- This system is designed to any motorcycle, thanks to NASCAR software.
- The upper and lower arms are airplane grade aluminum alloy.
- Progressive Dual, five-position coil/over shocks, on each side for a smooth ride.
- Rear braking is provided by Willwood calipers and drilled rotor.
- The unit is topped off with an anti-sway bar and stainless steel bolts throughout.
- Reverse via electric motor, released when trike put in gear.
- Independent Suspension gives you a Soft Ride; this keeps your body and spine from feeling every single bump and hole in the road.
All wiring is clean and neat on this trike, I am a Retired Navy Electronic Technician by trade.
Big torque and horsepower combined with the cruiser look on a Trike is a winner all around.
The VTX1800 is notorious for being a motorcycle that likes to be ridden and is a highway machine.
This great looking bike is for sale now!, make it yours. :thumbup:
[email protected] subdude2
1 - 1 of 1 Posts
