1 - 11 of 11 Posts
Recently purchased a 2007 vtx 1300c (8700 miles). Vibrations are so extreme at mid to high speed, objects in the mirrors are a blur...
Both tires have been checked for balance, bearings are good, as well as the air pressure...Any VTX experts near Birmingham, Al?
Thanks in advance
Welcome....Sounds like buyers remorse...did u not Acquaint yourself with bike before purchase...the bikes have certain harmonics to them....Make sure u match RPMs to speed...others will be along ...good luck Newb....
Thanks in advance
Should not be "Extreme" vibration, have the mechanic ride it and tell you if it's "Extreme" or not.
Thanks TennX... yes, (first time rider)....you are correct, high RPMs..
Objects in the mirror a blur---that is correct. Two headlights look like four.
As a new rider to a VTX it seems strange. Later it will be the norm.
You will get used to it.
Any modifications??? Exhaust, Air/Fuel. Some harmonics can be amplified.
When I removed the OEM mufflers and put on some short JCWhitney,
a nasty harmonic at about 52 MPH indicated. It made me want to puke.
They did not stay on long. HK pipes installed. Clanging sound was ugly,
I made a dozen variations of baffles, some more vibes, some less.
My 1300 sounds rougher when the Main fuel level is about to run out.
Check ALL the rubber vacuum hoses. They crack on the interior wall.
You may want to check fuel flow, 2007 petcock had a recall.
Remove fuel hose (abt 3/8"ID) from petcock. Apply vacuum to petcock valve, full flow from petcock.
Either position a can or bottle to recover the fuel running out.
Folks what buy a MC and want a smooth ride should get a car..... ;) ..such is the nature of the beasts.......but having said that when I first got mine ...members clued me in...(y)
Discussion Starter #9
THanks, I will check that as well.
Discussion Starter #10
Everything appears to be stock.......
Check the vacuum hoses.
Read the recall and see if it has been done.
test fuel flow.
1 - 11 of 11 Posts
