1 - 14 of 14 Posts
Hello - I have 2007 1800F with 2000 miles that I have owned since new. I have everything except fuel (or so I think) to start engine. Bike will fire if I inject fuel into the throttle body. No error codes, newer battery & voltage is good, fuel pump sounds like it is pressuring up and then stops after 3-4 seconds. FI lights up as usual (no blinks) and then turns off. Spark plugs just cleaned. All of the threads I can find are for pre-2005 that show a fuel pressure regulator. I have disconnected main fuel line and lifted tank but it appears that there is only a fuel rail and no FPR. Should I check the fuel flow by disconnecting the fuel line going into the rail? Also, if I do, will there still be enough fuel in the system for the test? Thank you.
2,000 miles... when was it last ridden?
Injectors could be clogged up. There is a fine mesh screen on the injector.
Fuel filters in canister could be clogged.
3-4 seconds of FP running is the prime..If it is cranking or running than FP continues to run..
Take off fuel line and see what comes out..
Discussion Starter #4
Last ridden about 4 mos. ago for only about 1 mile. Can’t seem to find repair manual pdf for 2005-2008 except for Clymer or original Honda (used) for $134 so I am kind of in the blind. Where is the canister with the fuel filters located? I will update you after I remove the incoming line to the fuel rail and check the fuel pump pressure if I can find a fitting that works. Thank you both for the feedback.
If only 2000 miles on a 2007 bike then this bike is being mistreated. How old is the gas that is in the tank? If old , drain the old gas out and replace with fresh and change the fuel filter
Discussion Starter #7
Thanks for the replies and link. I will try to check pressure at the rail or pump outlet and go from there.
Discussion Starter #8
Fuel Problem Resolved
Problem was fuel injectors. Made contact multiple times with leads from power source to injector terminals until I could hear the solenoid each time. Fired right up after that.
Thank you Hans&Feet and Ervin for your recommendations. Saved me from flatbedding it to Riva Motorsports, who knows how many diagnostic hours and they would probably want to install new injectors, etc.
Solenoid in the injector.
Strangely enough I read about someone pulsing the injectors recently..
https://www.google.com/imgres?imgurl=https://upload.wikimedia.org/wikipedia/commons/2/29/Injector3.gif&imgrefurl=https://en.wikipedia.org/wiki/Fuel_injection&tbnid=lKI_ZUd69kYb-M&vet=12ahUKEwjG9JT6zZrlAhWMKlMKHbaNDeEQMygIegUIARChAQ..i&docid=NocEO-9Kt-lrHM&w=941&h=588&q=gas fuel injectors&hl=en&ved=2ahUKEwjG9JT6zZrlAhWMKlMKHbaNDeEQMygIegUIARChAQ
Hans, Ervin, a few others: You fellas are really great with your knowledge and willingness to help us lesser VTX guys. You deserve a bit more credit for your efforts. :bowdown:
1 - 14 of 14 Posts
