My bike does not want to start. I have changed the plugs. Check the starter switch and cleaned it. Check the fuel lines for leaks holes cracks. Done about everything that I can possibly do.i'm getting fuel to the carburetor.
take one of the old plugs hook any of the plug wires to it and ground it to the bike hit starter and it should spark.
don't get fingers around the tip or they will get zapped
okay no spark pull the seat and inspect the wires going to the ECU on top of the battery.
the black and or green wire may be broken inside the insulation you can wiggle them a bit while you try and start.
If you have a battery charger you may want to top off the battery too since you have been cranking it a bit
