Changed my oil this weekend. Had to drive a screwdriver through the filter to get er off no biggy..
Since I live in ARizona, I thought I should use 20W-50 oil, but now I am reading that it is not necessary since the engine is liquid cooled. Will this cause any problems. Also, I only had one new crush gasket for the drain screw, so I only opened the back screw on my C and drained it through there and the filter. Quite a lot of oil came out, seemed like most of it and it was open for over an hour draining. Any problems with that? I am sure there is problem a reason there are two bolts...
