1 - 10 of 10 Posts
OK, once you've stopped laughing out loud and picked yourself up off the floor, please help me with this question.
Which gear do you normally use to maintain 55 to 60 MPH? Or, asked another way: Can I do any harm to my machine during the break in period using all that torque at low RPMs?
Thanks in advanced for your help!
Jim
Still grinning!
55 to 60 MPH
You are always better off keeping the engine rpm's in a higher range than lugging the engine. Higher R's keep oil pump and water pump spinning faster for better lube and cooling needed for a 'tighter' new engine. Taz
i'll cruise at 50mph in 4th, if i shift to 5th at 50 and give it some gas it shakes and kinda chugs.
Each bike is different
2 up go into 5 as I pass 60.
Slow crusing 50 or so.
Just ride her she will let you know when to shift
There is no absolute answer. It all depends on many parameters.
If I am just cruising down a straight and level road without any wind effect I would shift into 5th at 40 mph. If I was still accelerating, I would not shift until a minimum of 50 mph. If I was enjoying myself, getting up to freeway cruising speed, I would shift at an average of 80 mph.
Much of it is "becoming one with the machine".
As you put those miles on your bike, you will phase from being a rider to becoming part of the assembly of man and machine. You will develope the habit of revving a little higher before you shift as you demand more acceleration.
Try these shift points for different demands:
10-20-30-40
15-30-45-60
20-40-60-80
Just ride it and have fun!
8)
This is an interesting thread. I, too, experienced lugging in 5th at state speed limit of 55 and often need to cruise at 60-65 to smooth out 5th gear. I believe this monster would feel much better cruising in 5th around 75mph. Where I live, there are no superhighways, mostly rural country roads and two lne blacktop with deer, woodchucks, creatures big and small, slow school buses and such. So, during daily travel I'm always looking to smooth out 5th.
1 - 10 of 10 Posts
