S
Seven79
·Guest
I’ve read that we should use an accessory lead to power a distribution block. Most people on here states that the license plate light would be a good lead. Where do I find this wire?
i looked and only sat a fuse box (small) and the battery access. I have a vtx 1300R. Am i crazy?Others use the brown tail light wire under the right side cover.
Use the positive side of the battery. But, use a relay powered by the the accessory side of the stock fuse holder. A relay takes very little power to activate and it will only supply power with the key on.I’ve read that we should use an accessory lead to power a distribution block. Most people on here states that the license plate light would be a good lead. Where do I find this wire?
