I have a 2002 1800vtx-c. I recently upgraded my amplifier to a1000watt system. My question is, will my stock charging system be adequate enough to sustain the extra wattage or should I add a 1 farad capacitor to compensate?
I know very little about that stuff, but I do know that the Honda VTX electrical system is already at near max capacity as it comes stock from the factory. Maybe reduce some of the loads by switching all lights to LED.I have a 2002 1800vtx-c. I recently upgraded my amplifier to a1000watt system. My question is, will my stock charging system be adequate enough to sustain the extra wattage or should I add a 1 farad capacitor to compensate?
I don't know, never done it. Are you doing this for the first time? Give us some background on the project?I have a 2002 1800vtx-c. I recently upgraded my amplifier to a1000watt system. My question is, will my stock charging system be adequate enough to sustain the extra wattage or should I add a 1 farad capacitor to compensate?
Not if you run the amp at full volume all of the time. Your question, re: capacitor, makes no sense. A capacitor does nothing for the sustained output of the charging system. IOW, no, it won't help.I have a 2002 1800vtx-c. I recently upgraded my amplifier to a1000watt system. My question is, will my stock charging system be adequate enough to sustain the extra wattage or should I add a 1 farad capacitor to compensate?
Yes, I am doing this for the first time.I don't know, never done it. Are you doing this for the first time? Give us some background on the project?
Yes, this is my first time. As for the project, Im installing a Dual Bluetooth stereo, backed up by 6 Pyle speakers at 350/400 watts respectfully and the amplifier I'm using is a Dual DA10004D. And it's all going into a fairing which is supported by my 2002 1800vtx-c w/30,000 miles (pictures enclosed) Any and all help would be appreciated. Thank youI don't know, never done it. Are you doing this for the first time? Give us some background on the project?
No it does not, but it helps sustain voltage drop, which in turn (w/the extra stored up juice the capacitor gives) helps power amplifier which the bikes charging system won't.Not if you run the amp at full volume all of the time. Your question, re: capacitor, makes no sense. A capacitor does nothing for the sustained output of the charging system. IOW, no, it won't help.
Thanks, already have.I know very little about that stuff, but I do know that the Honda VTX electrical system is already at near max capacity as it comes stock from the factory. Maybe reduce some of the loads by switching all lights to LED.
Sort of, but the battery in the system has that capability in spades. Here's the thing, when you put a 1000w amp in the trunk of your car and are driving enough speaker to shake the ground, then you cable it with #6AWG or bigger to minimize the effective loss due to current surge. Then you'll want a big capacitor to keep the amp from clipping. Because your battery is no further away from your amp than a capacitor would be, there's little benefit. Neither your battery or charging system are up to driving a 1000W amplifier at those sorts of volume levels. Remember a car will have a 100A or bigger charging system. Your bike has nothing close to that. Your battery is a fraction of the size.No it does not, but it helps sustain voltage drop, which in turn (w/the extra stored up juice the capacitor gives) helps power amplifier which the bikes charging system won't.
It is something to consider, but expensive if we're talking about 12v motorcycle batteries.I have read lithium battery capacity is independent of discharge rate. It constantly delivers the same amount of power throughout its discharge cycle.
In lead-acid batteries, the rated capacity decreases with an increase in discharge rate.
Run your system on two?? lithium batteries?
Just something to consider.![]()
Although the amp is rated @1,000 watts peak power, it's out-put is 240 RMS.Sort of, but the battery in the system has that capability in spades. Here's the thing, when you put a 1000w amp in the trunk of your car and are driving enough speaker to shake the ground, then you cable it with #6AWG or bigger to minimize the effective loss due to current surge. Then you'll want a big capacitor to keep the amp from clipping. Because your battery is no further away from your amp than a capacitor would be, there's little benefit. Neither your battery or charging system are up to driving a 1000W amplifier at those sorts of volume levels. Remember a car will have a 100A or bigger charging system. Your bike has nothing close to that. Your battery is a fraction of the size.
All of this assumes a quality 1000W (for real) amp. There's a lot of cheap junk out there offers a fraction of what they say it will. Driving more will result in clipping, no matter the supply because the internals are incapable. They give 1000w in theory, but in practice they can't ever do it cleanly.
Honestly, 1000w on a motorcycle is way more than what makes sense. Both for practicality and logistically. I'd expect electrical issues. Let's remember though, that the amp power consumption is largely dependent on how loud you crank it.
Thanks, that's common, yet an important distinction. Is there a current rating on the amp itself? Just guessing, you'd need a continuous 25 to 30A at full volume. Your lights are your biggest draw. Your headlight at 55W (65W high beam) and your marker lights at about 10W ea.Although the amp is rated @1,000 watts peak power, it's out-put is 240 RMS.
Item | Peak draw | Usage |
Headlight (high beam) | 65 watts | Intermittent |
Headlight (low beam) | 55 watts | Constant |
License plate light | Five watts | Constant |
Brake light | 20 watts | Intermittent |
Tail light | 15 watts | Constant |
Instrument Cluster | Three watts | Constant |
ECU/ECM | 25 watts | Constant |
Fuel pump | 60 watts | Constant |
Cooling fan | 60 watts | Usually intermittent during winter months |
Ignition | 50 watts | Constant |
Horn | 45 watts | Intermittent |
Exactly. Another consideration is that when you draw the system voltage below 14.5V for an extended period of time you are also drawing excessive current for an extended period of time. Your regulator, normally goes between periods of high current draw and normal current draw. This helps modulate the temperature in the stator with design specs. Continuous overcurrent builds a lot of heat in the stator, definitely limiting it's life. It is also excessive for the rectifier and you can expect limited life there as well. The regulator portion of the R&R though, should last forever.No, your VTX will not sustain the battery with that much stuff on it. As said, you can add another battery to run just the stereo system and then charge that with a battery charger when you stop. Or, you can buy a bike that has the capacity to run all those extras. On the subject, there is no upgrade alternator to produce more power.
You ride it like that, eventually your system will drain the power and the bike will stall. EFI needs power to keep the fuel pump going
The amp itself has 2-25a. I'm holding of on the capacitor and installing larger guage wires (to the amp, stereo and speakers) i will keep you informed on the progress of this project. Thank you for your help.Thanks, that's common, yet an important distinction. Is there a current rating on the amp itself? Just guessing, you'd need a continuous 25 to 30A at full volume. Your lights are your biggest draw. Your headlight at 55W (65W high beam) and your marker lights at about 10W ea.
Here's a rough list;
Item Peak draw Usage Headlight (high beam) 65 watts Intermittent Headlight (low beam) 55 watts Constant License plate light Five watts Constant Brake light 20 watts Intermittent Tail light 15 watts Constant Instrument Cluster Three watts Constant ECU/ECM 25 watts Constant Fuel pump 60 watts Constant Cooling fan 60 watts Usually intermittent
during winter monthsIgnition 50 watts Constant Horn 45 watts Intermittent
The system can output 364W @ 5000rpm. Less as rpm diminishes. You'll need reserve to actually charge the battery. Again, your amp will use something in line with where the volume is at. Keep it on 11 and your battery will be dead. Still, it's a lot of amp for a bike.
