1 - 20 of 25 Posts
This is long, so be prepared. Hopefully, its worth the effort. The object here, is to give our readers a good baseline of information about how their VTX's work, and address some of the most common questions produced on this forum in a thoughtful and complete way.
Having read hundreds of posts on these topics, I decided to take a stab at writing something to clarify the many misconceptions on this subject. Whether it’s interminable questions about backfiring/popping, or arguments about “load”, or discussion about whether aftermarket fuel computers are necessary and which is best, we see a lot of bad information and mistaken ideas being tossed around as fact. So lets take a look at the basics, and then talk about a few specifics.
Pressure is the thing
The single most important thing to understand about an internal combustion engine is that at its very root, it’s nothing but an air pump. If you can get your mind around that one simple concept, understanding everything else is a lot simpler and more straightforward.
Ever consider your own lungs? As it happens, your body is also a pretty efficient air pump. When you take a breath, your diaphragm muscle contracts and pulls your lungs downwards in your chest, and this increases their size by stretching them. This increase in volume causes a decrease in pressure (applies vacuum) to your windpipe, and this causes air to rush into your chest. Air always flows from an area of high pressure to an area of low pressure. How fast it flows, depends on the difference in pressure. The bigger the difference, the faster air moves. The bigger the volume, the more air needs to move to equalize the pressure. When you exhale, the reverse happens – your diaphragm relaxes, causing the volume in your lungs to decrease, which increases the pressure inside your lungs, which makes air flow out of your windpipe – to the outside air, which is now at a lower pressure than your lungs.
The pressure is the thing. Differences in pressure make the air move. All around you, at this very minute, is a bunch of air that stretches up above you for several miles. The weight of all that air, presses down on the air below it, and causes the air that surrounds you to be under pressure. This is called “atmospheric pressure”. It is the baseline around which we talk about the pumping of air. You should understand something else here, the concept of “vacuum”. Vacuum, at least with respect to motors, just means “lower pressure than atmospheric”. If you create a vacuum, what you are really doing, is creating an area where the air pressure is lower than the surrounding atmospheric pressure. If you give it a way to do so, air is going to try real hard to kill that vacuum by sending air into it. Nature abhors a vacuum. Air always moves from an area of high pressure to an area of low pressure, and the amount of force it does so with is proportional to the difference between the two pressures. Sounds simple, no? It really is, but it also confuses folks.
Remember I said a motor was just a big air pump? It is, and it works exactly the same way your lungs do. On the intake stroke, as a piston travels down its cylinder, the area in the cylinder increases rapidly – and causes a vacuum. When the intake valve opens, air rushes into the cylinder, and causes a drop in pressure in the intake manifold that is proportional to the amount air moving into the cylinder. On the exhaust stroke, the burning fuel and air has created very high pressure in the cylinder, and when the exhaust valve opens, the pressure in the exhaust header is much lower than the cylinder, so the gas rushes out into the exhaust pipe.
If this sounds simple or obvious to you, then great. But make sure you really do understand these concepts, because understanding the way a motor works means understanding the sequence of pressure changes. If you don’t understand, then none of the rest of this is going to gel for you.
Different Strokes Move the World, Willis.
Ok, now its time to see what the air pump really does, and what drives it, and that means understanding strokes. For the purposes of this article, we’ll focus on a 4-stroke motor, since our bikes use them, and since the vast majority of motors are 4-strokes.
Lets simplify, and look at each stroke.
Intake stroke – This is the first stroke in our series of four. In this one, the piston is moving downward in the cylinder with the intake valve open, causing a vacuum to be created in the cylinder and more importantly, in the intake manifold where the carburetor or fuel injectors live. The vacuum (area of low pressure) created in the intake manifold is the power that drives the fuel system, and gets the fuel into the cylinder where we want it. The larger the vacuum (lower the pressure), the more fuel is pumped into the cylinder. The faster the piston moves downward in the cylinder, the bigger and faster the vacuum is created, and the more fuel gets pumped. Therefore, it also follows, that the higher the engine’s RPM, and the harder an engine is working, the higher the vacuum (or lower the pressure) exists in the intake manifold.
At this moment, I hope your brain is saying to you “whoa – that vacuum measurement is sure an important number to know if I’m going to know what my motor is doing”. Damn skippy it is – so lets define something important right now:
The amount of vacuum produced by a motor is a direct measurement of the load placed on the motor. Therefore, when discussing motors, Load means the amount of air being demanded by a motor, which is equivalent to the amount of vacuum developed in the intake manifold, which is the same as the pressure difference inside the manifold and the outside air.
Woo! Now we understand the mysterious load. It’s a great number to know, and is used by fuel injection computers to determine how much fuel to squirt into the intake manifold. It’s also the energy that makes a carb shoot a given amount of fuel out of its jets. We’ll talk about carbs and fuel injection a little later, so lets move on with the strokes.
Compression Stroke – Ok, the piston has moved as far down in the cylinder as it possibly can on the intake stroke (called bottom dead center or BDC), and starts its way back upward. The intake valve closes and so we have a volume of air and fuel trapped in the cylinder, and suddenly the space it occupies is gonna get squished real hard (compressed), as the piston begins moving upward in the cylinder. This causes the pressure in the cylinder to increase very rapidly, since the charge has nowhere to go. One thing to remember here – fuel burns much faster under pressure.
Power Stroke – Ok, all the valves are closed, we’ve got our air/fuel charge compressed really tight, and put it under a lot of pressure as the piston gets to the very tippity top of it’s path through the cylinder (called Top Dead Center). At this point we set the charge on fire, and as it burns it produces a whole bunch of gas, which rapidly increases the pressure in the small space, and pushes the cylinder downward very hard. This is where all the power in your motor comes from, this rapidly expanding gas pressure. A couple of things to note here.
First, we ignite the mix using the spark plug. If the plug were to fire at exactly top dead center (TDC), we could arbitrarily call that the zero position of the crankshaft, and indeed, that’s exactly what we do. Remember, the crankshaft is rotating in a circle throughout this process. One rotation of the crankshaft (360 degrees) means one complete up and down motion of the piston. When we talk about “timing” in a motor, what we’re really talking about is the relationship of the spark to the moment of TDC or the zero position of the crankshaft. If we fire the spark plug before TDC (BDTC, or during the end of the compression stroke), we call that advancing the spark. If we fire the plug after (ATDC, or during the power stroke), we call that retarding the spark.
Exhaust Stroke – Ok, the piston is now hauling ass downwards, and the cylinder is full of hot and probably still burning gas and residual fuel/air. As the piston crosses bottom dead center (BDC) again and starts upward, we enter the exhaust stroke. During the stroke, the exhaust valve opens, and since the cylinder is now at a much higher pressure than the exhaust pipe, all that hot gas and stuff goes flying into the exhaust header, and out the pipe. That’s the end of the 4 strokes, and when the piston crosses TDC again, the whole process starts anew, and away we go.
A couple of things to note here. You’ll notice, that during all four strokes, the crankshaft rotates two full rotations, and travels through 720 full degrees. The camshafts, which actuate the valves, have traveled through one full rotation, or 360 degrees. You often see guys tossing around degree measurements when discussing things like spark timing, cam timing, cam profiles, and so forth. So it’s important to be able to relate the concept of degrees, to the actual rotation of the parts. If you were really good at math in school, you’ll immediately notice that any given instant in the cycling of a motor can be described using simple trigonometry, which should give you some pretty important insights into the ways fuel injection computers and electronics work on your motors. But that’s a bit lofty a subject for this article, so lets move along, shall we?
It Gives me Gas
Well, now that we’ve got the strokes, let talk about gas, and the fuel system in general. I’m going to focus on describing a fuel injection system, because once you understand that, understanding a carbureted system is vastly easier.
So. We know that load (or vacuum demand) is the way fuel is delivered to the cylinder, but how does the motor know how much fuel? And how much fuel is actually needed?
Lets start, by talking about the air/fuel ratio.
A ratio, just means “amount of one thing compared to amount of another”. In our case, it means amount of air compared to the amount of fuel. When you see someone talk about air/fuel ratios, they usually put the air part first, followed (or divided) by the fuel part. So an A/F ratio of 13 to 1, or 13-1, or 13/1 just means “thirteen parts air to one part fuel”.
Now, lets talk a little simple chemistry. The burning of air and fuel is just a chemical reaction called combustion. Chemical reactions are described by chemists in chemical equations, and the science of balancing these equations, or determining how much of each chemical reacts, is called “stoichiometry”. Lets look at a simple one:
1O2 + 2H2 --> 2H2O
It’s a little hard to read that, but it just means “One molecule (consisting of two atoms) of Oxygen plus two molecules (consisting of two atoms each) of Hydrogen will react and form 2 molecules of water”. You’ll notice, that in this reaction, everything gets used up, and no atoms are left over, and so the reaction is said to be “stoichiometric” (i.e. nothing is left over), and now you know where that big word comes from that gets tossed around when people talk about A/F ratios. It just means “completely burnt with nothing left over”. Glad we got that out of the way.
Now that we understand stoichiometric A/F ratios, lets define a couple of things.
An A/F ratio is said to be “Lean”, when there is air left over after burning.
An A/F ratio is said to be “Rich”, when there is gasoline left over after burning.
Now, the perfect stoichiometric A/F ratio varies based on a lot of factors, like the formulation of the gasoline, or the density of the air, but in general, we can say it’s in the neighborhood of 14.7 parts of air to one part of gas, or 14.7/1 (the VTX really likes 13/1 to make best power).
So now we understand ratios, and what ratio we are aiming at, but how does the motor get the right amount of gas in to make that ratio? Vacuum, that’s how.
A carbureted motor does it directly, by varying the size of its jets. The carb sits in-line between the outside air pressure (air filter) and the manifold pressure (load or vacuum). The action of the air flowing through it into the manifold causes suction in the jets, which pull gas out of the bowl, and spit it into the intake manifold. The bigger the jet, the more gas gets spit out for a given vacuum. But it’s a little different in a fuel-injected motor, since the fuel injectors are turned off and on by the computer (ECU). So how does the computer measure the load to know how long to turn the injectors on? By using sensors.
There are several involved in this process, with the most important being the “MAP” (manifold absolute pressure) sensor, which directly measures the pressure in the intake manifold. The computer then compares this pressure to the outside air pressure, or barometric pressure (obtained by reading the BAR sensor), and now knows just how much vacuum the motor is pulling. In order to get load though, the computer needs to know how much air is being pulled into the cylinders, so it needs to know the air density as well. It does this by looking at the intake air temperature measure by the “IAT” sensor. The ECU has a table of density values in it that compares density at various temperatures and pressures. It just takes the values it read from its IAT and (adjusted) MAP sensor, looks up the density value for these readings in its table, and “hey presto”, your ECU now has a direct measurement of the load on your motor. Now that the ECU knows the load, it just has to figure out how long to turn the injectors on to get the right A/F ratio (which it does by looking it up in a fuel table by comparing load to RPM), and boom – we got gas. The same table is also used to look up the right time to fire the spark plugs (timing). Honda calls this “three dimensional fuel programming”, and I guess that’s sort of accurate.
There are other sensors that play less important roles in the process, like O2 sensors on California bikes, WTS (water temperature sensors), and so forth. But the MAP senor is the big one.
The pleasure of the Sensors
By now, you've probably heard someone say that "every bike runs a little different", and maybe you've wondered why. Didn't all these bikes come off the same assembly line? Didn't the same machine mill all the heads? Isn't it the same configuration, and the same parts? Why do they run different?
It's a fair question. The answer, is that your tune is derived from the plasure of your sensors.
Thing is, no two sensors will report the exact same reading from the exact same thing they are measuring. The reasons for this are many, but the biggest is that Honda doesn't require absolute accuracy from the companies it buys sensors from. They allow a certain amount of variance and error right from the get go. So that MAP sensor from Denso might have a stated accuracy of +- .1v at 90 degrees or whatever. This guarantees right from the start, that you have a certain spread in the tune achieved by the ecu's of all bikes, because there's a spread in what their map sensors are reporting as the manifold pressure. Beyond that, other things can skew the readings reported by the sensors as well - things like outside temperature, dampness in the wires, oxidation in the wire harness, etc. The age and condition of your wire harness greatly effects the resistance of your wiring, and this in turn directly effects the voltages reported by your sensors. Remember Ohm's Law?
Voltage = Amperage x Resistance
So, if you vary the resistance, and the amperage is the same, then the voltage varies. And the ECU reads voltage from the sensors to determine what the sensor is measuring.
So since everyone has a wire harness in different shape, and all the sensors are varying a little in the first place, we end up with bikes tuned all over the map. Thus, we need to find a way to bring our fuel curves back where we want them, and compensate for the error introduced by our wambly sensors.
After Market Fuel Computers
This is a good time to talk about aftermarket fuel controllers, so lets hit on what they do real quick. The 1300 guys can manipulate their A/F ratios by changing jets, but it’s a bit more complex (and expensive) for the 1800 riders. For the VTX, there are basically three types of controller available. All three do exactly the same thing – they manipulate the amount of time the injectors are turned on during the intake stroke, by intercepting the voltage the ECU sends to the injectors. How the decide how much longer or shorter to turn the injector on, varies a bit though, and that variety is important thing to know when selecting which controller to use on your bike (if in fact you choose to use on at all – none of them are ever really necessary, regardless of what pipes or airboxes you add on to the bike.)
It’s also important to understand this: None of these controllers is ever a necessity, regardless of whether you change pipes or airboxes on your bike. The stock ECU will, in almost every case, adjust to the changes in airflow you’ve caused, and give you a reasonably good A/F ratio. But you should understand, that the ECU is not programmed to give you an A/F ratio that is optimized for horsepower from the factory – instead, Honda worries about things like pollution, engine temperature, and rider perception, and so the ECU can be said to be “de-tuned” in order to address these other concerns. Likewise, you have a certain amount of error introduced by your wambly sensors. So the real function of these add-on controllers is to correct the error (or eliminate the de-tuning) that Honda induced in your fuel curve on purpose, and to compensate for the error in your fuel system sensors, in order to reclaim the lost horsepower and improve engine efficiency (possibly at the cost of making more pollution, hearing more deceleration backfiring, etc). Adding on aftermarket pipes or airboxes can sometimes exaggerate this de-tuning as well, so we need to be able to modify our fuel curves to match the configuration of our bikes. Got that? These boxes aren’t really necessary, but if you’re hunting more horses, they can sure find them. Likewise, it's almost impossible to get your bike in perfect tune without one.
So lets talk about the specific boxes:
TFI – This unit is marketed under several brand names by Techlusion, Cobra, DFO, and others. It does one thing, and one thing only – it extends the fuel pulses produced by the ECU, and therefore, it can only richen the fuel mix – and never ever lean it. Typically, these units are designed to act like variable fuel jets – by adjusting two or three settings, you can add more or less fuel to the mix for a certain RPM range – usually low, middle, and high. It determines RPM by looking at the signal frequency produced by the ECU. Because these units are extremely simplistic, they won’t really optimize your fuel curve, although they can reduce or eliminate decel popping, or sometimes correct a really lean condition, But in all cases, your fuel curve will vary from lean to rich along it’s total fuel curve, so you’re only going to help the lean spots, and hurt the rich spots. These units get sold with a lot of pooey about bikes always being lean, or “knowing load”. It’s crap, since we’ve seen hundreds of fuel curves off the dyno now that amply demonstrate that most VTXs run a little lean at low rpms, and rich in higher rpms (as a rule, but not always). This load nonsense is just that, since all of the available fuel controllers modify the signal produced by the stock ECU. Therefore all of them “know load”. Don’t get suckered by marketing malarkey. Frankly, while these units can reduce decel pop, I can’t see that as a goal worth achieving, and so I never recommend these units. I think you can do better, for slightly more money.
Power Commander III – This device also modifies the fuel output from the ECU, but does so based on a table of values referencing the throttle position sensor (TPS), and rpms. Since the position of the throttle plates directly affects the amount of air being allowed into the engine, the value of the TPS is a pretty good substitute for the “Load” value derived from the map sensor by the ECU. In effect, the PC3 produces an overlay curve of its own, and this can be manipulated to correct the de-tuning in the stock ECU, and for sensor error. PC3’s can either lean or richen the mix, and so are capable of completely correcting the fuel curve produced by the stock ECU. Because the new curve is applied proportional to load, its effective regardless of the ambient air pressure – since the curves are proportional. Tuning the PC3 correctly requires a session on a dynometer, so these units are somewhat expensive – but set up correctly, they will produce optimum fuel curves under nearly all conditions. Of course, changing equipment on your bike will mean the curve is no longer a perfect match, and another adjustment session may be required in order to get a perfect fuel curve, so the PC3 is not without its gotchas. But for best performance, the PC3 comes out on top. It’s a very flexible and effective unit. Newer PC3’s also have functions that can emulate a tunable accelerator pump, or allow you to map each cylinder independently. Good stuff.
HPP – This unit adjusts the output fuel pulse by manipulating the value of the MAP sensor, based on calculations derived from reading the oxygen content of your exhaust with an O2 sensor. In theory, this results in a “closed loop” system, one that adjusts itself looking for optimal F/A ratio by reading the exhaust in real time. In practice, the O2 sensors are pretty inaccurate at higher RPMs, and so the device does some educated guessing, and therefore the fuel curve isn’t always perfectly optimized. However, experience has shown that properly set up, these units perform very well, and are an excellent alternative for someone who doesn’t want the hassle of fiddling with their fuel tables, or going to dyno sessions. They can also adapt when new equipment is installed on the bike. So this is the unit to use when performance with convenience is your goal, and you are willing to give up a few percent of horsepower to gain that ease of use. Decent stuff, not perfect. Unfortunately, these are no longer being made, so a used one is the only way you'll find one. Note also, no support, no repairs available, etc.
"Alpha-N" fuel controller - This unit has been recently released, and claims to be a fully closed loop system - meaning it uses feedback from an O2 sensor to optimize itself at runtime. Like the PCIII, it uses the throttle position sensor and RPM to determine an approximation of the load currently placed on the bike. It uses narrow band sensors only, so the accuracy of the Fuel/air ratio measurement is rough, and so it will tend to produce more accurate results at cruise, than under acceleration. However, this unit is so new, that we have very little experience with it here on VTXOA. And so we'll have to wait and see how it will perform. In theory, it could be a very good box, but experience has shown that the gap between theory and fact is often wide, and so some skeptical thinking is required here when considering it for purchase. Once I've gotten one of these on a dyno, I'll revise this and report on it's efficacy. As usual, it comes packaged with the usual outlandish marketing claims. It's also fairly pricey, although it could be considered comparable to a PCIII + a custom dyno tune.
Alas, there is currently no unit on the market which can manipulate the timing tables, and that sucks. These big motors cry out for the ability to optimize timing tables to match configuration or changes to the fuel tables, and there’s no doubt that 4 or 5 horsepower lurk in the inability to manipulate the spark. Perhaps someday Dynojet will follow through on their promises to provide a timing module, but until then, the ability to manipulate spark effectively simply doesn’t exist. I yearn for a fully programmable ECU. I also yearn for a 20 year old hottie with great legs and big boobs. I’ll probably get my timing before I get the boobies though – more’s the pity.
Burn Baby Burn
The last thing I want to address today is the subject of deceleration backfire, or “popping”. This topic generates a lot of concern from inexperienced riders, or even from experienced guys who just hate the noise, so lets take a look at what causes it. But first things first, lets define the issue:
Deceleration Backfire is caused by fuel burning in the exhaust manifold or header.
No ifs ands or buts, that’s what causes it. But the bigger question is how does gas get there in the first place, and that’s a bit more complicated. Generally, there are a variety of ways it gets there, and a variety of things that can make the backfiring worse. But there’s a kicker, and something you should understand before we go any farther:
A motor in perfect tune will exhibit deceleration backfiring.
Therefore, just because your motor is banging it up, doesn’t mean there’s anything wrong. And consequently:
Getting rid of the noise means de-tuning your motor.
Yup. If you’ve jut got to eliminate that popping, you’ll have to accept the fact that your motor is going to be forced to run rich to do it, and that isn’t necessarily a good thing. So lets talk about what causes the problem.
Ok, so you’re riding along at some given rpm, and suddenly you decide to decelerate, and you reduce the amount of throttle. This causes an “overrun” – that is, the motors rpm is turning faster than the fuel provided can support, so the motor begins to spool down. This causes a couple of things to happen.
First, when you close the throttle, you are also closing the throttle plates. This reduces the air and fuel flowing into the motor, and increases the vacuum (lowers the pressure). This results in less air and fuel in the cylinder during the power stroke, which in turn results in a lower pressure in the combustion chamber. Remember I said earlier, that the A/F mix burns faster in proportion to the pressure applied? Well, when we reduce pressure this way, the mix burns slower. This results in two things happening.
1. The lower burning fuel generates less heat, and the cooling effect of the non-burning fuel tends to “quench” the flame front, or slow it down even further. Because the mix is burning much slower, the exhaust valve can open before all the fuel is consumed, and the unburnt fuel is ejected into the exhaust.
2. The engine designers, in order to promote smoother idling and better combustion, retard the spark when the throttle is shut, and this results in the mix being lit later.
So, now we end up with unburnt fuel in the exhaust, and burning fuel being ejected into the exhaust, and bang! Backfire. In addition, Honda has added a device called a “programmed air injection valve” (Pair Valve) that actually injects some fresh air into the exhaust to help this process along – since fully burning the fuel results in cleaner exhaust. So the backfiring is not only a normal part of the engines operation, it’s also intentionally amplified by Honda! Of course, normally, that massive bazooka pipe Honda hangs on your bike hides most of the noise, but it’s there, even when you can’t hear it.
So the bottom line, is: That backfiring is perfectly normal and expected. If you’ve just got get rid of it, that’s up to you. You’re entitled to set your motor up the way you want, and your goals are your goals. But don’t refer to it as “fixing” the popping. Rather, the correct way to think of it is “de-tuning a bit to get rid of the popping”.
There are a few ways you can do this.
First, use the stock pipe. It will hide the sound, by absorbing it into mass, and masking it with the larger baffle space. Second, you can add more fuel during deceleration. This has the effect of raising the chamber pressure slightly, which burns a little more before the exhaust valve opens. Lastly, you can remove the Pair valve, which reduces the amount of available oxygen in the pipe to burn the unburnt fuel.
Well, there you go. I hope this long piece has given you some information you can use, or clarified things a bit for you. I may ultimately add to this, and discuss valve timing, the effects of compression on performance, or other topics as they motivate me. In the meantime, feel free to criticize, correct, or just tell me how dumb I am. I’m still learning too, after all.
Tapper,
A most excellent post. Glad someone pubically acknowledged what I have been saying all along........that the stock ECU can self adjust (to an extent) to match air box and pipe mods and that aftermarket fuel managers are not always needed.
A couple of items. First, in the section on the four stroke engine, you say.....
"The vacuum (area of low pressure) created in the intake manifold is the power that drives the fuel system, and gets the fuel into the cylinder where we want it. The larger the vacuum (lower the pressure), the more fuel is pumped into the cylinder. The faster the piston moves downward in the cylinder, the bigger and faster the vacuum is created, and the more fuel gets pumped. Therefore, it also follows, that the higher the engine’s RPM, and the harder an engine is working, the higher the vacuum (or lower the pressure) exists in the intake manifold."
I thought from my college thermo class (yep, its been a long, long time and I may be fuzzy) that the vacuum created in the engine was strictly based on the compression ration of the cylinder (open volume vs closed volume). That would make both vacuum and compression independent of RPMs. Regardless of how fast the engine is turning, the compression ratio should be constant. But it occurs at a faster pace, meaning the engine is working harder and the load has increased.
Just a minor point.
Also, please say something about the octane issue. There are a lot of folks on this board and others that still think that 91 or 93 octane will make their bike "run" better, not understanding that higher octane gasolines simply allow an engine to utilize a higher compression ratio without the fear of preignition. Higher octane fuel is a myth propogated by the oil companies, like the mandatory 3000 mile oil change.
BTW, I agree about the ignition timing. Until we can vary the timing on the fly, the VTX will never truly utilize all the ponies it is capable of producing.
Once again, great post!
Scarecrow
Scarecrow,
Bear in mind that while the maximum and minimum intake pressures possible are a function of the cylinder volume at BDC, the actual amount of air drawn into the cylinder is a rate - i.e. so many cubic feet per minute. So the higher the RPM at a given pressure, the higher the CFM produced. Or more specifically, the maximum vacuum is a function of the cylinder volume across the intake cam duration. Perhaps I could have made that clearer.
Re: Tapper's treatise
Bob Hamby said:
Tapper, great job, thanks for putting all that info together. I finally feel at ease after reading your article. For the last two weeks I have been trying to find out why my bike decel backfires, I don' mind the sound. at first I thought it was just the nature of a high performance engine. I have done all the fixes, de-smog, ground fix, pair covers, intake / exhaust clamp torque and spark plug check. Last nght when I took the bike out it still backfired therefore I concluded it must be running lean and I would have to buy a fuel manager. Would I be correct in thinking I can open up my airbox and the ECU would adjust the injector pulse for the increased air flow without an aftermarket fuel manager? By the way my plugs look almost new they are so clean, 3k on them and the bike ran strong at the drags.
Thanks again for putting together a great post.
Bob
It should run fine, but you may not get much benefit from the opened up airbox without a fuel controller.
Tapper,
In your response to scarecrow you stated the following:
Being somewhat new to this I was wondering a few things. I think I answer my own questions below, but.....
1. Obviously there is a cap to the amount of air that can be drawn into the cylinder, right? Is there a way to determine the maximum pressure on the fly? What I am getting at here is how do I remove restrictions on the air flow to ensure I max out the pressure in the cylinder during the intake? Do I want to do this, or is there some sort of catostrophic engine failure lurking around here that this newbie is unaware of?
2. I think this may be the answer i am looking for, but I guess I am testing myself. If I put a new cam shaft in that has a longer intake valve duration am I fixing this issue?
3. Does the X have any issues with to little fuel getting added to the mix? I am specifically asking about the 1800. Based on reading this I would bet that you would need to reject the 1300 at some point if you introduced enough air, is there some sort of fuel injector fix or does the fuel injector handle any flow of air possible up to the limit mentioned above?
I hope these questions make sense, I am not an engineer but I am trying desperately to understand this process. This stuff is fun to figure out!
Discussion Starter #7
Mowoc said:
Tapper,
The absolute cap is the volume of the cylinder at BDC, however, this is functionally limited by a several things, the most important being the intake cam duration, and the flow rate of the manifold assembly. These factors can be manipulated, either by changing cams or by porting the heads, modifying the manifolds, polishing, etc. Maximizing the air charge is part and parcel of hot-rodding the motor, since it's a lot easier to squirt in more fuel than it is to get more air in. As to failure, any time you increase horsepower, you also increase stress on the motor - and increase the possibility for failure. There's always a trade-off.
You can put in new cams to increase the duration or lift, and this can result in getting more air in, yes. You can also reduce airway restrictions in the air intake systems, like adding a higher flow air filter, increasing the airbox orifice diameters, increasing the size of the manifold itself, porting the heads, etc. All will increase the size of the air charge.
The 1800 is typically programmed lean through the first 2500 rpms or so, and rich thereafter. The ECU will handle increases in air flow up to a certain extent, but will not necessarily provide an optimum A/F mix - for that you need an aftermarket device like the PCIII, HPP or TFI units.
Makes sense, and you're right, figuring all this stuff out is a lot of fun!
Trapper...
I'm thinking of carving a design on my airbox cover to let more air in. Will the onboard sensor adjust for the extra air, or am I going to need a fuel management unit?
Thanks,
Rog
Discussion Starter #9
Rowder said:
Trapper...
Thanks,
Rog
It well, but bear in mind it will also exagerrate "error" Honda programmed in for emission purposses, and sosmetimes this can get to the point it causes problems. Try it and see.
Guys, it Tapper. T - A - P - P - E - R. There's also a Trapper on this board, and while he's probably a good guy, I doubt he'd be thrilled to be mistaken for my ugly mug.
:oops:
Air fuel piece
WOW!!!!!!! :shock: that was an awsome write up Bro!! I'm a Navy jet mechanic and been workinig with engines for 18.5 years (in the Navy), but that piece just blow's me away. I'm new to the VTX world, but not new to bikes and Hot Rodding. I do feel that I am better educated now on how this 1800 motor works, with all the new computer stuff on it, I'm old school here! Carburation Baby!! 8) but in the jet world we have some of the simular things, but instead of a fuel injected carb system we use a fuel control, which cost more that 10 VTX1800's new!! Tapper, great job! I too feel at ease with this thing, and well worded for the little guy's like myself :D . I look forward to seeing more of your tech stuff. Are you open too questions if I have any on theis bike??
Discussion Starter #11
I'm always open to questions, but all you really need to do, is post the question here on the tech board. There's a bunch of knowledgeable folks here that will try and help, and several more knowledgeable than I.
Say Tap, have you given much thought to the differences in the CA model ECM as apposed to the 49 state models in terms of efficiencies in adjusting F/A ratios? Given their partial closed loop configuration and use of an O2 sensor for feedback in the low end rpm's, I've always wondered what the fuel curve looks like on a CA bike as apposed to a 49 state model. Likewise, one would wonder if a CA model would be more or less likely to experience Decel popping all things being equal.
Mike
Discussion Starter #13
You know, I've seen almost no data on the CA models with respect to the O2 sensor. ECU's can use them in so many ways, I can't even speculate without being able to play with one a while.
Lower quality O2 sensors tend to be used to build modifier values by doing some simple statistics on readings at various rpms. I'm going to guess that's what the Honda sensor is doing, but it's just a guess.
J
Guest
De Tuning Hell / Starved More Like it
I read your entire article. Another reader asked and i think rightly so why does enrichening the fuel cause the popping to go away? That was the first question that came to my mind. You said you covered that. You did say if you ran rich it would quiet it down but did not explain why. It sounds like two opposing principles. I had pipes put on my bike and the honda shop did not nothing to the Power Commander III USB except load a stock 2003 1800C map into it. It popped and to be honest did not have all the impressive "power" i have been hearing everyone rave about. I tuned the Computer up for richer and i have about 25% more power in my bike. The bike was starved! It runs smoother and has power through out the curve and sounds better. Deeper rumble almost no popping. I pulled the plug after a good run and it was not running wet or black. So although your engine 101 article is good, the two opposing principles you suggest dont make any damn sense to me.
JP
I've been thinking about that since I posted. For combustion you need the right mixture of fuel, air, and ignition, whether it's in your cylinder or your exhaust pipe. I've been weighing some options
1. The added gas slows the combustion in the exhaust pipe so it burns more controlled, and doesn't pop as much.
2. The added gas changes the mixture, makes it too rich, and the combustion never starts.
3. The combustion in the cylinder is more complete, leaving less unburned fuel for the pipes
4. The added fuel keeps the cylinder cooler, the unburned fuel in the pipe does not get ignited.
What are your thoughts?
Discussion Starter #16
Richening up the mix reduces popping because it leaves more gas in the cylinder during overrun, which tends to slow the flame front during overrun (due to low pressure effects) to the point where it won't burn fast enough in the exhaust to make any noise.
Discussion Starter #17
Re: De Tuning Hell / Starved More Like it
Hum......? Makes a lot of sense to me, and I'm not even all that smart :)
mike
JP
First, if you'll read the directions on your PCIII, I think it pretty clearly states: You need to take your bike with the PCIII installed to a dynojet tuning center, and have a custom map made. Just jacking in more fuel might help in some places, but it will hurt in others, and end up ruining your gas mileage. Every bike is a little different, a custom maps means you should be in perfect tune. No map, means you are not in perfect tune - by definition.
Second, dumping a "factory vtx" map in, just means loading a map with all 0's in it - and therefore the PCIII is doing nothing whatsoever to you fuel curve.
J
Guest
mike
My point is that when you say a detuned engine has no popping noise and a tuned engine back fires or pops it is a subjective statement. Your definition of a bike that backfires (like its supposed to?) and my definition of proper back fire or lack thereof is superfluous. The real answer is getting the bike on the dyno. You cant tell someone an engine is right because it backfires. You may be giving them the wrong information and a biker is riding a bike that is starving for fuel. Not good for the bike right? I know on the side of lean is the enviormental concerns and I am sure the Honda company line that leaner is better. Anyway i guess your right you arent that smart, at least you didnt get what i was getting at.
JP
Discussion Starter #19
First, in no way have I said that "backfiring" was always a sign of a properly tuned engine. Backfiring can also be a symptom of a faulty motor system as well. What I said was, that properly tuned engines frequently snap, crackle, and pop in the exhaust headers (this is not, strictly speaking, backfiring). This is almost a certainty in the VTX, because of the way the ignition timing is set. In a VTX, when you shut the throttle, the ECU retards the timing, on the principle that we want the fuel mix maximally compressed at low fuel flows to promote full burn at idle, and indeed that is important to maintain a smooth idle. However, when the engine is in an overrun state (i.e. when going from a position of relatively high rpm to a position of relatively low RPM), this is exactly backwards - you want to advance the timing a little (light the mix early), to prevent unburned fuel from flushing into the exhaust (and making bang noises, particularly as a working PAIR valve feeds the partially burned mix new oxygen). Note- This suggests that the ECU relies heavily on the TPS sensor to determine ignition table values.
J
Guest
Tapper this does make sense to me; i appreciate your commentary.
1 - 20 of 25 Posts
