1 - 12 of 12 Posts
Can anyone help? Speedo and odometer both stopped working at the same time. All indicator and riding lights still work. I have read all the threads. Checked the green plugs (broke the clasps in the process). Tightened the battery terminals, checked the ground plug. Swapped fuses. Nothing has fixed it.
Check the speed sensor, bottom left side under the clutch cable. You will have to pull the chrome cover off.
That would seem the logical choice for both going out a once. I am searching here for tips on replacing the speed sensor
VSS outputs +5v pulses when the rear wheel is turning---white wire.
G/Bl is the ground wire.
Bl/Br is the +12v wire (to power a chip)
Main harness wire colors shown.
Check the green plugs look closely,closely -sometimes the pins can be pushed back into the connectors and not make contact. Broken clip - place a small zip tie threw the wires on each plug and around both plugs to pull them together. mine have been that way for years.
Donut/Doug
I thought I checked the plugs pretty well. Am going to check from the VSS tomorrow and work my way back to the harness. Dealer told me they hardly ever see a speedo unit go bad. Will update again after I check it all. Thanks for all the help.
Discussion Starter #7
OK, I did the wiring checks per the service manual pg 19-6. All seems to be correct.
Next I metered the White and Gr/Black wire per the manual and advice from this thread, with the harness connected, on the speedo side. turned the key on and get a solid 4.5 volt reading. Even when moving the bike. No pulse as expected.
Could this be a limitaion of my digital volt meter? Not sure what to do next. Any ideas?
Mine had definite voltage/no voltage readings when turning the wheel.
68 to 72 pulses per revolution. My digital meter showed 1.8~ when turning and 3.31~ when stopped... I also had a Led flashing.... MY cheap meter averages some of the pulses apparently.
Discussion Starter #9
I checked everything again. Turned the wheel very slowly with key on. My meter reads 4.58 volts as soon as I turn on the key and never changes. Started moter and it worked exaclty the same. I am sure my voltmeter was the cheapest one Walmart sells. Will borrow some one elses and try again. Thanks a bunch for all your advice.
Sounds bad. Damn shame they are so expensive. Probably 3 major components in there: pickup coil, Schmitt trigger, and a 5 volt regulator.
>>And I was talking about my cheap meter<< A friend gave it to me. A HF unit..
Discussion Starter #11
It just dawned on me that all the videos and information online show the wires coming directly from the speed sensor wiring. I have mine connected off of the green plugs on the upper right side under the gas tank. I thought that is where I should be checking for a pulse. Is that incorrect? Should I only see a pulse at the speed sensor?
Since there is a connector by the left side engine cover it would be good to check there. Open the connector and look for the pulse. A few VSS have died this year. I really like testing with a Led also. Led and 330 Ohm resistor makes for a good tester.
1 - 12 of 12 Posts
