Here's what the mfgr says about the product:
Product Description
Radiator Relief™ supercharges your radiator by transferring heat more efficiently through the radiator. This proven coolant additive will reduce your operating temperature up to 30 degrees and cut engine warm up time in half. The majority of engine wear occurs at the extremes- extreme heat and extreme cold start ups. Radiator Relief™ can help reduce this wear and extend engine life by minimizing those extremes. • 30 degrees lower operating temperature • 50% quicker warm up • No mixing required; drain a quart - add a quart • Compatible with water and all anti-freeze mixtures • Safe with all alloys • 100% Biodegradable, Non-Corrosive and Non-Toxic • For use in all water cooled engines
http://www.designengineering.com/produc ... =sp&pid=35
Here's a link from a 4x4 rock crawler web site:
http://www.rockcrawler.com/features/new ... relief.asp
I found quart size bottles by googling. Sounds interesting, just not sure if it's worth it, so thought I'd throw it out here for the masses.
Later
Remember the old saying ..If it sounds too good to be true..? I think this should get the snake oil of the day award.
