1 - 17 of 17 Posts
I reported this before.
Having trouble posting and get this message alot.
The server is too busy at the moment. Please try again later.
So I do and often end up with duplicates I can't delete.
Please help.
Administrator
Please help.
Mark here, one of the techs.
That error should not be happening. VB throws that error if the server load is high. We both don't have high load, and we don't use that feature, it ignores the load.
To try and work around this, I've changed the setting to a very very very high load (which we will never hit). Please let us know if you continue to get these errors.
Mark
Discussion Starter #8
Thanks Mark
It has something to do with my account.
No problem when I am not logged in but of course I can't post.
When I login I get the too busy message or not found message 5-10 times.
It took many tries to post this.Do you have an email I can contact you on?
Sometime I get the message and the post has gone through resulting in duplicates.
I don't have problems with any other site.This all started when you guys took over.
Budley3 -
Try this ...... create a new post.
Hit the submit button and do nothing else.
Shut down the browser, and restart going back to the thread and you will see your thread/post is there.
Constantly hitting the SUBMIT button does nothing be create more unnecessary posts/threads.
You have been told about this work-around on numerous occasions.
It's probably a connection problem related to your ISP - call them and ask them if there is a way you can test for dropped packets.
STOP hitting the SUBMIT button more than once.
There is a reason why only YOU are having this issue .... and it's not the site.
On the other hand, maybe you are exceeding your daily BS limit! :mrgreen:
Then please stay on those sites. Maybe, but I doubt it someone might want you there, here not.
Discussion Starter #14
Thanks Mr VTX
I tried all that and had the computer checked by our local computer experts.
Its disturbing that I can't even get a response from the new guys although I sent many emails and pm messages.
Administrator
Is anyone else encountering this issue?
budley3, is this only happening when you post? What about when you are trying to do other things on the forum? (browsing threads, checking notifications, sending a private message)
~ Alan, Community Support
Discussion Starter #16
Others may have given up.
I have to try many times to do anything and I get a lot of duplicates because it tells me the site is busy and to try again.Then I can't erase the duplicates.
Discussion Starter #17
Alan
I don't have any problems moving around and reading posts if I am NOT logged in so that would indicate there is something wrong with my account.
The minute I log in it's difficult to open posts and move around the forum.
I get the not found message or the site is too busy message 4 out of 5 times.
1 - 17 of 17 Posts
